Hello,
I had to replace my router / modem and right after the replacement the ATV trailers stopped reaching the Plex server.
The ATV DNS is set to the static IP of my plex server: 192.168.124.111
log of plexconnect:
14:02:12 PlexConnect: started: 14:02:12
14:02:12 PlexConnect: Version: 0.4
14:02:12 PlexConnect: Python: 2.7.9 (default, Dec 10 2014, 12:24:55) [MSC v.1500 32 bit (Intel)]
14:02:12 PlexConnect: Host OS: win32
14:02:12 Settings: getsetting enable_plexconnect_autodetect=True
14:02:12 PlexConnect: IP_self: 192.168.124.111
14:02:12 Settings: getsetting hosttointercept=trailers.apple.com
14:02:12 Settings: getsetting enable_dnsserver=True
14:02:12 Settings: getsetting enable_webserver_ssl=True
14:02:13 WebServer: started: 14:02:13
14:02:13 Settings: getsetting port_webserver=80
14:02:13 DNSServer: started: 14:02:13
14:02:13 Settings: getsetting port_dnsserver=53
14:02:13 Settings: getsetting ip_dnsmaster=8.8.8.8
14:02:13 Settings: getsetting prevent_atv_update=True
14:02:13 DNSServer: ***
14:02:13 DNSServer: DNSServer: Serving DNS on 192.168.124.111 port 53.
14:02:13 DNSServer: intercept: [‘trailers.apple.com’] => 192.168.124.111
14:02:13 DNSServer: restrain: [‘mesu.apple.com’, ‘appldnld.apple.com’, ‘appldnld.apple.com.edgesuite.net’] => 127.0.0.1
14:02:13 DNSServer: forward other to higher level DNS: 8.8.8.8
14:02:13 WebServer: ***
14:02:13 WebServer: WebServer: Serving HTTP on 192.168.124.111 port 80.
14:02:13 ATVSettings: init class CATVSettings
14:02:13 ATVSettings: load settings
14:02:13 Settings: getsetting port_ssl=443
14:02:13 Settings: getsetting certfile=./assets/certificates/trailers.pem
14:02:13 WebServer: WebServer: Serving HTTPS on 192.168.124.111 port 443.
17:01:49 PlexConnect: Shutting down.
17:01:49 WebServer: Shutting down.
17:01:50 WebServer: Shutting down.
17:01:50 ATVSettings: save settings
17:01:53 DNSServer: Shutting down.
17:01:53 PlexConnect: shutdown
Settings.cfg
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = ./assets/certificates/trailers.pem
loglevel = High
logpath = .
Any idea what’s wrong?
Thanks!
