Help needed. do i have o e instal?
hello all!
i have just updated my apple tv 3 to the latest version
i also have to say that i had to clean install OS X Yosemite
still have the pleconnect folder oj my desktop
my though is
do i have to re generate the certificates and use the configuration utility?
or i just have to run the terminal commands to start the plexconnect?
i tried running the sudo plexconnect.py bgot the ip and configured it on the apple tv but nothing happened....
any help ideas?
You can Download OpenPlex or follow the Official Plexconnect guide:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Mac
There is also a easier way to load certs over the network instead of the usb method. OpenPlex guides you otherwise follow this:
https://github.com/iBaa/PlexConnect/wiki/Install-Guide-Certificate-via-Ethernet
first of all thanks!
do you think that due to the fact that i did a clean install i have to generate and install the new certificates to the apple tv?
haven't used openplex so not familiar with it :(
Not sure, here is a video on how to install OpenPlex if that’s what you decide to use:
https://www.youtube.com/watch?v=upEE9JghOcw
I would recommend deleting your old certs all together from your Mac and ATV and using new ones.
Not sure, here is a video on how to install OpenPlex if that's what you decide to use:
trying to use openplex
on the pillow step where when you press the install button it opens up terminal
in my mac it doesn't do anything :(
If you installed a theme first and CLT it should work, click the pillow button again. If that doesn't work quit terminal then reopen terminal and type this in:
pillow.bash
If you installed a theme first it should work, click the pillow button again. If that doesn't work quit terminal then reopen terminal and type this in:
pillow.bash
in all the process showing on the video i never had terminal open
should i have it open when pressing the pillow button?
It should quit terminal and open terminal back up on its own if terminal is open. CLT is required to be installed prior to installing pillow.
so confused
have installed ibaa theme (clue line under instal;)
and hone i press pillow no terminal window opens:(
Install Teamviewer, click my username and send me a message with the temporary teamviewer ID and password and I will take a look.
installing now:D
OpenPlex was installed and guided user to install PlexConnect. Mark as answered if desired.
App error was due to git update that occurred today from 2.0.1 to 2.2.1. New app pushed to prevent this error, OP topic updated.
would like to thank you and publicly since you guided and fixed my issue fast and without any issues!
really appreciate that
and as i said..its nice to see some good people around!!
thank you once again!
