Hi!
So i decided to open this topic because i could not find much information about what plex is doing to solve this “problem”.
System Info:
CPU: i5 3330 @ 3.0 GHz
Memory 8 Gb DDR3 Dual Channel @ 1333
Primary storage: Kingston 120 Gb SSD (OS in Same SSD of Plex Server)
Windows 10 Pro Build 1803
Plex-Media-Server-1.13.1.5063-b4605f76e (Plex Pass)
Modem: Technicolor TC7300b
My ISP just migrate to IPv6 and after that i was unable to connect Plex outside my home. I got the message " Not available outside your network" I already tried to do a port foward on Technicolor router but still get the same problem. I Also tried to connect over a VPN but i was always disconnected from the service and then PMS goes “not available”.
I Also tried to do DMZ on Technicolor router and open ports on D-link DIR-878 but got same result.
I am here with some questions:
1 - The settings option “Custom server access URLs” can help to bypass the DoubleNAT? How can I set up?
2 - Is there any “beta test version” that Plex is working to fix DoubleNAT? If yes can I be one beta tester?
3- My D-link DIR 878 is compatible with dd-wrt can i use it? It helps?
So, I know a lot of people has the same problem and that´s the reason why i ask how things are going to fix this? I see in some topics that Emby does not have this problem but i am trully a Plex lover and i don´t want to change it
Maybe if plex can create like a service that can get your IP?
Last…if you know any VPN that really works let me know!
Hope someone can help me with this!
THX,
Braz.
