help or info to build a personal movies scanner
after applying a while with plex, configuration, photos, movies, personal videos. I am blocked, and need a little bit of help please.
I use pled for 3 things :
movies : ok, this part works like a charm.
photos : this part works well. I need more EXIF infos, but it will be another thread.
personnal video : it is not usable for me.
what I would need is the flexibility of photos representation in pled viewer, for personal movies.
let me explain what is good with photos :
if I build a photo library, I will have on disk :
photos
             2002
                      march
                                  photo 2 .jpeg ...
                     party with Joe
                                             photo xyz.jpeg ....
when I use the browser, or the IOS app, I can enter in the different subfolder, and see all my picture, really easily.
the best would be I Can do the same with personal video.
I got some scanner on internet, but none are doing what I need, and after looking everywhere, I don't find the solution.
I would like to be able to have the same representation than photo, but with personal movies.
imagine that above, I replace all .jpeg by .mp4
you have, all of you, see what is the result with photos,
how can I update a scanner, in order to use the same behavior than photos, but with showing video instead.
many thank you for any tips, link, hep, etc...
I am so disappointed to not find a solution, Plex is so powerful.
thanks
Olivier
