HELP! Pictures automaticlly delete after library scan
Server Version#:1.25.3.5409
Hi all
New to Plex, having fun!
Problem adding photos. I added the libraries and scan. Shows 300+ photos added, then trash cans start popping up, deleting photos. By the time it’s done it’s deleted all but 63. Why?
Any help is greatly appreciated
Thank You
MAL
The red trash can implies Plex can no longer see/access the file associated to a library item. If you have configured your library to automatically empty its trash after every scan, those will be deleted (see Settings > [Server Name] > Library > Empty trash automatically after every scan).
This configuration can be quite dangerous in combination with automatic/periodic scans (also Settings > [Server Name] > Library) and a storage with a wonky connection… sometimes it’s enough if an external / network storage is particularly slow to spin up or being mounted to a different path / drive letter.
Now… your case seems odd as the items are being added and deleted in one go.
Can you confirm the files are still available and accessible to Plex (e.g. correct permissions in case you’re on a Linux based system / NAS)?
Thanks tom80H for the very quick response. I am on my way to work will address your comments when I get home. TY
MAL
I went ahead and unchecked the "Empty trash automatically…"in the libraries.
Some more background that should answer tom80H’s questions.
Regarding the 63 photos that are not being deleted. They are in the Pictures directory. All the photos that are being deleted are in sub-directories in the Pictures directory.
Not using NAS. all files are local, on the machine hosting Plex server.
All the files are accessible and have full permissions. See ls -l output below.
mark@Thunderbolt:~$ ls -l
total 68
drwxrwxrwx 2 mark mark 4096 Jan 11 14:44 Desktop
drwxrwxrwx 1 mark root 4096 Dec 24 17:37 Documents
drwxrwxrwx 1 mark root 4096 Jan 10 23:24 Downloads
drwxrwxrwx 1 mark root 20480 Jan 13 09:05 Music
drwxrwxrwx 1 mark root 16384 Jan 12 13:00 Pictures
drwxrwxrwx 2 mark mark 4096 Dec 19 06:20 Public
drwxrwxrwx 2 mark mark 4096 Dec 23 08:54 Temp
drwxrwxrwx 2 mark mark 4096 Dec 19 06:20 Templates
drwxrwxrwx 1 mark root 4096 Jan 12 08:42 Videos
drwxrwxr-x 2 mark mark 4096 Dec 24 15:26 Warpinator
mark@Thunderbolt:~$ cd Pictures
mark@Thunderbolt:~/Pictures$ ls -l
total 3712
drwxrwxrwx 1 mark root 0 Jan 12 13:00 0Mark
drwxrwxrwx 1 mark root 4096 Dec 8 12:49 12082021
drwxrwxrwx 1 mark root 36864 Apr 14 2016 August2011
drwxrwxrwx 1 mark root 4096 Jan 12 12:58 ‘BBG TO DO’
drwxrwxrwx 1 mark root 8192 Jan 12 12:52 ‘February 2013’
drwxrwxrwx 1 mark root 4096 Apr 14 2016 Mar2013
-rwxrwxrwx 1 mark root 92086 Jan 20 1998 megangrandpaJoel1297
-rwxrwxrwx 1 mark root 78149 Jan 20 1998 megantumble1297
-rwxrwxrwx 1 mark root 116472 Dec 25 17:20 photo1.JPG
-rwxrwxrwx 1 mark root 126462 Dec 25 17:22 photo.JPG
-rwxrwxrwx 1 mark root 15511 Sep 5 2011 PremioDestellosBrillantesEnElCieloAzul.jpg
drwxrwxrwx 1 mark root 12288 Jan 12 12:51 Sept2011
mark@Thunderbolt:~/Pictures$ cd Sept2011
mark@Thunderbolt:~/Pictures/Sept2011$ ls -l
total 1920
