I have a problem with a Blu-ray rip that I can’t seem to figure out. The Blu-ray has an aspect ratio of 1.78:1, but Plex thinks that it is 1.33:1 instead. The XML file in PLEX says that the file is 1.33, and I cannot figure out how to fix this issue.
The file plays in widescreen in VLC, and MediaInfo shows the MKV file as 16:9 (1.78:1) as it should.
I cannot get PLEX to stop thinking that the file is 1.33:1. I have deleted the file from PLEX and re-ripped it multiple times and it works perfectly everywhere other than PLEX.
The playback is incorrect on all my media devices. I have three NVIDIA Shield devices, and it displays incorrectly on each of them, as well as the PLEX player on my Windows 10 computer.
The file plays perfectly in VLC, and the aspect ratio is right in MediaInfo. If I look at the XML in PLEX, the aspect ratio shows to be 1.33. I can’t seem to figure out how to get PLEX to understand that it is 1.78:1 (16:9).
I used MKVToolNix and found that the segment cut from the larger file plays in 1.33 instead of 1.78:1 in VLC. I played the original file and it plays in 1.78:1 instead. When it is cut into small sections, the individual sections play at the wrong aspect ratio.
Do you still need me to upload sections of the movie? I can certainly do that if needed.
