Help! Plex dts ps4 & a New AV RECEIVER
I stream HD movies from my mac via pms to ps4 and LG tv.
How do I get the digital audio Dts HD etc to an av receiver I’m thinking of buying. Denon avr3300
Will the ps4 accept the dts via the wifi stream and pass it to the receiver to produce dts etc?
Or is there something else I need to do?
Matt
Thank you so much for your comment Trumpy81… that’s a pretty clear explanation!
Much better than the reply I got from plex when I emailed them.
Check out their comment… (Unabridged)
_"_Emilio (Plex, Inc.)
Feb 7, 3:21 PM PST
The PS4 app cannot play or passthrough DTS https://support.plex.tv/hc/en-us/articles/204377253-What-media-formats-are-supported"_
I asked the same question!
Is that the best way to do it then or would you recommend anything else?
Cheers
No problem Trumpy81 it still helped. :slight_smile:
I’m about to splash £600 on the Denon avr3300 I’m trying to figure out all other ways to get Surround sound for all those HD rips Ive got on my hard drives, i have an extensive plex library but maybe I need to find another way?
