DTS passthrough
Hi
I’m currently looking te renew my old TV and Surround system. I am running Plex on a Mac Mini, and PMS on a Synology NAS.
I was thinking of buying an Apple TV to replace my Mac Mini. But, apparently an Apple TV doesn’t pass through DTS sound, it is converted to PCM sound. Wowww, really.
In that case, I don’t need an Apple TV. I would prefer to have the maximum sound and image quality on my new system. I really would love to have the best experience. This brings me the question, does the same happen with a Mac Mini when connected to an AV receiver with HDMI cable.
If it really is the case, what is the best way to have DTS sound on a AV receiver using plex.
You know that this PCM stream is the decoded DTS audio stream – no degraded downmix? That is unless you’ve configured your Apple TV to transcode all audio to some Dolby Surround format.
Because I’m never clear how multichannel PCM is going to flow through my rig, I opt for DTS or AC3 pretty often, seeing as the video comes with it.
Yes licensing apparently. It’s common instead to go Mini → AVR → TV on older TVs without eARC.
That should work great, and Plex will send whatever encodes the AVR supports. Make sure the AVR is turned on before the Mini. If you want to give us some model numbers we can be more accurate.
Probably HDMI. Being old I’m happy to use Digital Optical or Digital Coaxial if necessary. There are some good Digital to Digital Adapters that pass through DTS & AC3 in that case, but they’re hard to find.
One is the Amazon.com
Another is the Hifime USB to Optical converter
Didn’t know that. So I shouldn’t be worried about using plex on a apple tv an watching movies with a DTS channel
Ok, shouldn’t be worried.
I don’t have any model numbers yet. Still analysing which surround and AV receiver I would like to combine.
thanks for the links, will have a closer look to it.
Damn I’m so out of touch.
I would have sworn that Plex transcoded audio to multi-channel FLAC on the Apple TV last I knew.
Unless that was specifically HD audio such as True-HD and DTS-X?
@scarlac
An HDMI connection is infinitely preferable to optical/coax.
Optical/Coax is limited to the following: AC3 & DTS up to 5.1 channels, and PCM 2.0. It has zero support for EAC3, TrueHD, Atmos, and DTS-HD/DTS:X.
When possible, the preferred method of connecting devices is:
Plex Client ← HDMI → Sound Equipment ← HDMI → TV/Display
This supports all current audio formats such as TrueHD + Atmos and DTS:X (if supported by the client & sound equipment).
It also keeps the TV out of the audio path. This is preferable as some TVs block passthrough of some audio formats. I know that is vague, but it varies by TV manufacturer. A specific example is LG, which now blocks passthrough of any DTS audio format.
When researching TVs, check the reviews at rtings.com. They test audio passthrough as part of their review process.
