Hello, I have been using Plex Media Server for a while now, but recently (since I built a new PC, and had my old one to spare) I decided to do a hardware upgrade, and upgrade all content I could to 4k x265 mkv files. The computer I am using is definitely powerful enough to transcode these files, and playback is very smooth on both direct play and when it needs to transcode to a lower resolution.
Server specs are as follows:
Windows 10 Pro (x64)
Plex Media Server Version 1.13.4.5251
Intel Core i7-4790k @ 4.0 GHz
8GB of DDR3 Memory
EVGA GeForce GTX970
Gigabyte GA-Z97X-Gaming 5 (Soon to be upgraded to a board with more PCIE lanes)
EVGA 650 watt power supply.
These specs are very temporary and not that “server grade”, especially with all the movies currently on a 1TB external HDD while I wait for a proper rack mount case with hot swap HDD bays.
The movie I used to test this was Guardians of the Galaxy 2. File size is around 17gb, and is a 4k, x265, HEVC, MKV file. The problem I am having is the stream suddenly stops (after completely flawless playback) and says “The transcoder exited due to an error”. This led me to wonder why something that works great when its working can fail so suddenly and without reason.
I initially thought this had something to do with overheating as back when I built this computer 3 years ago, I cheaped out on proper CPU cooling and instead opted to use the Intel Stock cooler.
I ruled out this reason for failure as the CPU doesn’t run above 80c for long at all, and it only reaches that temperature when the CPU usage hits 100%. (Which isn’t often, and not for long).
Further observations found that the “Plex Transcoder” process in Task Manager uses up a whole bunch of ram, and seems to crash once that process reaches around 3.7gb of used memory. This led me to wonder why it is crashing every time at around this number. Could it be a bad RAM stick? Or possibly not enough?
This is where I am stuck. Attached is the Server Log file (Hosted on Google Drive as new users cant upload files), and two videos on YouTube of the crash happening. It is pretty obvious when the crash happens. It reaches about 3.7gb of usage before completely quitting. After the transcoder crashes, I can immediately resume the video where I left off in the Plex App, and it will play flawlessly until memory usage hits that number, then crashes.
Any help will be greatly appreciated, as I have no idea where to proceed from here.
Thanks!
-Brett
YouTube Links:
Crash 1: Plex Transcoder Crash 1 - YouTube
Crash 2: Plex Transcoder Crash 2 - YouTube
Log ZIP File:
