Okay. so i externally collocate multiple machines and recently i moved everything to a much new server which left me with a server just sitting in the rack with almost nothing on it. i decided ide turn it into a plex media server. that being said. i have no “local connection” since the server its self is about 6 states away.
Anyways ive gotten everything set up correctly i can connect with my-ip:32400 but. i cannot discover the server even when using shh tunneling. ive also tried whitelisting my pc’s ips in the Preferences.xml.
The OS i use its ubuntu 16.04 lts server 64bit. i do not plan on using a “gui” based os as this is still used for a small web server and some game servers.
Could anyone possibly have an idea on what i could do to get this up?
Alright thanks that got everything fixed. for some reason putty just wouldn’t work so i had to use powershell to ssh and after that everything worked perfect.
