Help setting up plexconnect server
Hello, I can't figure out why the server won't startup. Any help would be greatly appreciated. This is what I'm getting in Terminal after running sudo ./PlexConnect.py
PlexConnect: started: 00:41:55
PlexConnect: ***
PlexConnect: PlexConnect
PlexConnect: Press ENTER to shut down.
PlexConnect: ***
PlexConnect: IP_self: 192.168.3.3
PlexGDM: ***
PlexGDM: looking up Plex Media Server
PlexGDM: ***
PlexGDM: servers discovered: 1
PlexConnect: PMS: 192.168.3.3:32400
DNSServer: started: 00:41:56
DNSServer: ***
DNSServer: Starting up.
DNSServer: intercept trailers.apple.com: 192.168.3.3
DNSServer: forward other to higher level DNS: 8.8.8.8
DNSServer: ***
WebServer: started: 00:41:56
WebServer: Failed to connect to HTTP on 0.0.0.0 port 80: [Errno 48] Address already in use
PlexConnect: WebServer not alive. Shutting down.
DNSServer: Shutting down.
Jake-Rogerss-iMac:PlexConnect-XML_templates jakerogers$ sudo ./PlexConnect.py
PlexConnect: started: 00:43:40
PlexConnect: ***
PlexConnect: ***
PlexGDM: ***
PlexGDM: ***
DNSServer: started: 00:43:41
DNSServer: ***
DNSServer: ***
WebServer: started: 00:43:41
If I type "sudo lsof -i -P", I'm getting this:
COMMAND   PID           USER   FD   TYPE             DEVICE SIZE/OFF   NODE NAME
launchd     1           root   12u  IPv4 0xffffff800b5c3dd8      0t0    UDP *:137
launchd     1           root   13u  IPv4 0xffffff800b5c3c60      0t0    UDP *:138
launchd     1           root   20u  IPv6 0xffffff800b8bbd80      0t0    TCP localhost:631 (LISTEN)
launchd     1           root   21u  IPv4 0xffffff800b8c1c20      0t0    TCP localhost.localdomain:631 (LISTEN)
UserEvent  11           root    4u  IPv4 0xffffff800b5c2ac0      0t0    UDP *:*
configd    15           root   11u  IPv6 0xffffff800b5c3970      0t0    UDP *:*
configd    15           root   17u  IPv4 0xffffff800b5c3218      0t0    UDP *:*
configd    15           root   22u  IPv4 0xffffff800b5c11c8      0t0    UDP *:*
configd    15           root   24u  IPv4 0xffffff800b5c1050      0t0    UDP *:*
configd    15           root   26u  IPv4 0xffffff800b5c0d60      0t0    UDP *:*
configd    15           root   29u  IPv6 0xffffff800cddedd8      0t0 ICMPV6 *:*
ntpd       19           root   20u  IPv4 0xffffff800b5bf468      0t0    UDP *:123
ntpd       19           root   21u  IPv6 0xffffff800b5bf2f0      0t0    UDP *:123
ntpd       19           root   22u  IPv6 0xffffff800b5bf000      0t0    UDP localhost:123
ntpd       19           root   23u  IPv4 0xffffff800b5c2948      0t0    UDP localhost.localdomain:123
ntpd       19           root   24u  IPv6 0xffffff800b5c30a0      0t0    UDP localhost:123
ntpd       19           root   25u  IPv6 0xffffff80191275e0      0t0    UDP jake-rogerss-imac.local:123
ntpd       19           root   26u  IPv4 0xffffff8019127468      0t0    UDP 192.168.3.3:123
ntpd       19           root   27u  IPv4 0xffffff800b5c27d0      0t0    UDP 10.211.55.2:123
ntpd       19           root   28u  IPv4 0xffffff800b5c2658      0t0    UDP 10.37.129.2:123
cupsd      20           root   11u  IPv6 0xffffff800b8bbd80      0t0    TCP localhost:631 (LISTEN)
cupsd      20           root   12u  IPv4 0xffffff800b8c1c20      0t0    TCP localhost.localdomain:631 (LISTEN)
cupsd      20           root   14u  IPv6 0xffffff800b8bb9c0      0t0    TCP *:631 (LISTEN)
cupsd      20           root   15u  IPv4 0xffffff800b8c1500      0t0    TCP *:631 (LISTEN)
cupsd      20           root   16u  IPv4 0xffffff800b5c0ed8      0t0    UDP *:631
mDNSRespo  38 _mdnsresponder    8u  IPv4 0xffffff800b5c37f8      0t0    UDP *:5353
mDNSRespo  38 _mdnsresponder    9u  IPv6 0xffffff800b5c3680      0t0    UDP *:5353
mDNSRespo  38 _mdnsresponder   24u  IPv4 0xffffff800cdf91a0      0t0    UDP *:50165
mDNSRespo  38 _mdnsresponder   25u  IPv6 0xffffff80191291c8      0t0    UDP *:50165
mDNSRespo  38 _mdnsresponder   26u  IPv4 0xffffff80191294b8      0t0    UDP *:56052
mDNSRespo  38 _mdnsresponder   28u  IPv6 0xffffff800cdf9780      0t0    UDP *:56052
mDNSRespo  38 _mdnsresponder   29u  IPv4 0xffffff8019129050      0t0    UDP *:61019
mDNSRespo  38 _mdnsresponder   30u  IPv6 0xffffff8019128ed8      0t0    UDP *:61019
mDNSRespo  38 _mdnsresponder   31u  IPv4 0xffffff8019128d60      0t0    UDP *:58662
mDNSRespo  38 _mdnsresponder   32u  IPv6 0xffffff800cdfaa98      0t0    UDP *:58662
mDNSRespo  38 _mdnsresponder   33u  IPv4 0xffffff800b5c1920      0t0    UDP *:53209
mDNSRespo  38 _mdnsresponder   34u  IPv6 0xffffff800b5c17a8      0t0    UDP *:53209
mDNSRespo  38 _mdnsresponder   35u  IPv4 0xffffff800b5c1630      0t0    UDP *:55457
mDNSRespo  38 _mdnsresponder   36u  IPv6 0xffffff800b5c14b8      0t0    UDP *:55457
mDNSRespo  38 _mdnsresponder   37u  IPv4 0xffffff800b5c1340      0t0    UDP *:52706
mDNSRespo  38 _mdnsresponder   38u  IPv6 0xffffff800b5c0be8      0t0    UDP *:52706
mDNSRespo  38 _mdnsresponder   39u  IPv4 0xffffff800b5c0a70      0t0    UDP *:61711
mDNSRespo  38 _mdnsresponder   40u  IPv6 0xffffff800b5c08f8      0t0    UDP *:61711
mDNSRespo  38 _mdnsresponder   41u  IPv4 0xffffff800b5c0780      0t0    UDP *:56396
mDNSRespo  38 _mdnsresponder   42u  IPv6 0xffffff800b5c0608      0t0    UDP *:56396
mDNSRespo  38 _mdnsresponder   43u  IPv4 0xffffff800b5c0490      0t0    UDP *:52566
mDNSRespo  38 _mdnsresponder   44u  IPv6 0xffffff800b5c0318      0t0    UDP *:52566
mDNSRespo  38 _mdnsresponder   45u  IPv4 0xffffff800b5c01a0      0t0    UDP *:60102
mDNSRespo  38 _mdnsresponder   46u  IPv6 0xffffff800b5c0028      0t0    UDP *:60102
mDNSRespo  38 _mdnsresponder   47u  IPv4 0xffffff800b5bfeb0      0t0    UDP *:50747
mDNSRespo  38 _mdnsresponder   48u  IPv6 0xffffff800b5bfd38      0t0    UDP *:50747
mDNSRespo  38 _mdnsresponder   49u  IPv4 0xffffff800b5bfbc0      0t0    UDP *:52512
mDNSRespo  38 _mdnsresponder   50u  IPv6 0xffffff800cdfcdd8      0t0    UDP *:52512
mDNSRespo  38 _mdnsresponder   51u  IPv4 0xffffff800cdfcc60      0t0    UDP *:59135
mDNSRespo  38 _mdnsresponder   52u  IPv6 0xffffff800cdfcae8      0t0    UDP *:59135
mDNSRespo  38 _mdnsresponder   53u  IPv4 0xffffff8019128a70      0t0    UDP *:65333
mDNSRespo  38 _mdnsresponder   54u  IPv6 0xffffff801912ac38      0t0    UDP *:65333
mDNSRespo  38 _mdnsresponder   55u  IPv4 0xffffff801912aac0      0t0    UDP *:54587
mDNSRespo  38 _mdnsresponder   56u  IPv6 0xffffff801912b390      0t0    UDP *:54587
mDNSRespo  38 _mdnsresponder   57u  IPv4 0xffffff800cdf8a48      0t0    UDP *:55654
mDNSRespo  38 _mdnsresponder   58u  IPv6 0xffffff801912b218      0t0    UDP *:55654
mDNSRespo  38 _mdnsresponder   59u  IPv4 0xffffff800cdf8eb0      0t0    UDP *:55259
mDNSRespo  38 _mdnsresponder   60u  IPv6 0xffffff800cdf8d38      0t0    UDP *:55259
mDNSRespo  38 _mdnsresponder   61u  IPv4 0xffffff800cdf9a70      0t0    UDP *:58416
mDNSRespo  38 _mdnsresponder   62u  IPv6 0xffffff800b5c3390      0t0    UDP *:58416
mDNSRespo  38 _mdnsresponder   92u  IPv4 0xffffff800cdfb7d0      0t0    UDP *:57801
mDNSRespo  38 _mdnsresponder   93u  IPv6 0xffffff801912b0a0      0t0    UDP *:57801
blued      51           root    4u  IPv4 0xffffff800b5c3508      0t0    UDP *:*
applepush  54           root   12u  IPv4 0xffffff800f950a40      0t0    TCP 192.168.3.3:57029->17.149.36.114:5223 (ESTABLISHED)
BkBackupS  55           root    0u  IPv4 0xffffff800b8c0de0      0t0    TCP localhost.localdomain:52693 (LISTEN)
BkBackupS  55           root    4u  IPv4 0xffffff801027ac20      0t0    TCP localhost.localdomain:52693->localhost.localdomain:49217 (CLOSE_WAIT)
BkBackupS  55           root    5u  IPv4 0xffffff8010278fa0      0t0    TCP localhost.localdomain:52693->localhost.localdomain:49219 (ESTABLISHED)
Belkin     59           root    7u  IPv4 0xffffff800b8c06c0      0t0    TCP localhost.localdomain:30010 (LISTEN)
Belkin     59           root    8u  IPv4 0xffffff800fe9ac00      0t0    TCP localhost.localdomain:30010->localhost.localdomain:49216 (ESTABLISHED)
Belkin     59           root   13u  IPv4 0xffffff800b5c1f00      0t0    UDP *:10111
Belkin     59           root   21u  IPv4 0xffffff800c795a40      0t0    TCP 192.168.3.3:57237->192.168.2.1:10101 (SYN_SENT)
netbiosd   97       _netbios    3u  IPv4 0xffffff800b5c3c60      0t0    UDP *:138
netbiosd   97       _netbios    4u  IPv4 0xffffff800b5c3dd8      0t0    UDP *:137
Google    272     jakerogers    9u  IPv4 0xffffff800cdf9490      0t0    UDP *:*
Google    272     jakerogers   69u  IPv4 0xffffff800f76d500      0t0    TCP 192.168.3.3:57028->vb-in-f104.1e100.net:443 (ESTABLISHED)
Google    272     jakerogers   82u  IPv4 0xffffff800b8bf160      0t0    TCP 192.168.3.3:57026->204.141.87.122:80 (ESTABLISHED)
Google    272     jakerogers   96u  IPv4 0xffffff801145e880      0t0    TCP 192.168.3.3:57035->qa-in-f125.1e100.net:5222 (ESTABLISHED)
Google    272     jakerogers  146u  IPv4 0xffffff8011504a40      0t0    TCP localhost.localdomain:57232->localhost.localdomain:80 (SYN_SENT)
Google    272     jakerogers  177u  IPv4 0xffffff80114c5320      0t0    TCP localhost.localdomain:57234->localhost.localdomain:80 (SYN_SENT)
Google    272     jakerogers  182u  IPv4 0xffffff80114714e0      0t0    TCP localhost.localdomain:57235->localhost.localdomain:80 (SYN_SENT)
Google    272     jakerogers  184u  IPv4 0xffffff800edf46c0      0t0    TCP 192.168.3.3:57041->edge-star-ecmp-10-iad1.facebook.com:443 (ESTABLISHED)
Google    272     jakerogers  187u  IPv4 0xffffff80114b3c00      0t0    TCP 192.168.3.3:57169->s3-1.amazonaws.com:443 (ESTABLISHED)
Google    272     jakerogers  188u  IPv4 0xffffff8011472320      0t0    TCP localhost.localdomain:57236->localhost.localdomain:80 (SYN_SENT)
Google    272     jakerogers  196u  IPv4 0xffffff80114cec00      0t0    TCP 192.168.3.3:57256->ec2-54-242-88-224.compute-1.amazonaws.com:80 (CLOSE_WAIT)
Google    272     jakerogers  205u  IPv4 0xffffff800d3e2c00      0t0    TCP 192.168.3.3:57259->ec2-54-243-239-217.compute-1.amazonaws.com:80 (ESTABLISHED)
Google    272     jakerogers  207u  IPv4 0xffffff80114b7500      0t0    TCP 192.168.3.3:57261->204.186.34.139:80 (ESTABLISHED)
Google    272     jakerogers  208u  IPv4 0xffffff800c8066c0      0t0    TCP 192.168.3.3:57262->204.186.34.139:80 (ESTABLISHED)
Google    272     jakerogers  210u  IPv4 0xffffff80114ebde0      0t0    TCP 192.168.3.3:57263->a184-31-162-110.deploy.akamaitechnologies.com:443 (ESTABLISHED)
Google    272     jakerogers  211u  IPv4 0xffffff80114f2c00      0t0    TCP 192.168.3.3:57081->lga15s28-in-f30.1e100.net:443 (ESTABLISHED)
Google    272     jakerogers  215u  IPv4 0xffffff80114cfa40      0t0    TCP 192.168.3.3:57264->a184-31-162-110.deploy.akamaitechnologies.com:443 (ESTABLISHED)
Google    272     jakerogers  216u  IPv4 0xffffff800e994880      0t0    TCP 192.168.3.3:57220->edge-star-ecmp-10-iad1.facebook.com:80 (ESTABLISHED)
Google    272     jakerogers  217u  IPv4 0xffffff8011469a40      0t0    TCP 192.168.3.3:57260->ec2-54-236-204-149.compute-1.amazonaws.com:80 (ESTABLISHED)
Google    272     jakerogers  220u  IPv4 0xffffff80114c8c20      0t0    TCP 192.168.3.3:57089->lga15s29-in-f6.1e100.net:443 (ESTABLISHED)
Google    272     jakerogers  223u  IPv4 0xffffff800e33ffa0      0t0    TCP 192.168.3.3:57170->s3-1.amazonaws.com:443 (ESTABLISHED)
Google    272     jakerogers  224u  IPv4 0xffffff8019239a40      0t0    TCP 192.168.3.3:57171->s3-1.amazonaws.com:443 (ESTABLISHED)
iTunes    274     jakerogers   28u  IPv4 0xffffff800b8bffa0      0t0    TCP *:3689 (LISTEN)
iTunes    274     jakerogers   29u  IPv6 0xffffff800b8bb600      0t0    TCP *:3689 (LISTEN)
iTunes    274     jakerogers   44u  IPv4 0xffffff8011489880      0t0    TCP 192.168.3.3:3689->192.168.3.10:49163 (ESTABLISHED)
iTunes    274     jakerogers   45u  IPv4 0xffffff801145f6c0      0t0    TCP 192.168.3.3:3689->192.168.3.10:49158 (ESTABLISHED)
iTunes    274     jakerogers   46u  IPv4 0xffffff800c7a94e0      0t0    TCP 192.168.3.3:3689->192.168.3.10:49159 (ESTABLISHED)
iTunes    274     jakerogers   47u  IPv6 0xffffff800b8bb240      0t0    TCP jake-rogerss-imac.local:3689->apple-tv.local:49179 (ESTABLISHED)
SystemUIS 279     jakerogers    7u  IPv4 0xffffff800b5c21f0      0t0    UDP *:*
Finder    280     jakerogers    9u  IPv4 0xffffff800b5c2368      0t0    UDP *:*
Finder    280     jakerogers   26u  IPv4 0xffffff801065dc20      0t0    TCP localhost.localdomain:55610->localhost.localdomain:26164 (CLOSE_WAIT)
Belkin    361     jakerogers    3u  IPv4 0xffffff800f95a500      0t0    TCP *:30011 (LISTEN)
SpotifyWe 366     jakerogers    6u  IPv4 0xffffff800f9f1c00      0t0    TCP localhost.localdomain:4370 (LISTEN)
SpotifyWe 366     jakerogers    7u  IPv4 0xffffff800f9f14e0      0t0    TCP localhost.localdomain:4380 (LISTEN)
Popup     371     jakerogers    5u  IPv4 0xffffff800f9f2320      0t0    TCP *:28212 (LISTEN)
Connect36 379     jakerogers    4u  IPv4 0xffffff801912bae8      0t0    UDP 192.168.3.3:9334->239.255.255.250:1900
Connect36 379     jakerogers    5u  IPv4 0xffffff800cdfa340      0t0    UDP *:1900
Connect36 379     jakerogers    7u  IPv4 0xffffff800fe9dde0      0t0    TCP *:9335 (LISTEN)
Connect36 379     jakerogers    9u  IPv4 0xffffff800cdfa340      0t0    UDP *:1900
Connect36 379     jakerogers   13u  IPv4 0xffffff800fe9dde0      0t0    TCP *:9335 (LISTEN)
Google    384     jakerogers   54u  IPv4 0xffffff801032d4e0      0t0    TCP 192.168.3.3:49248->qa-in-f125.1e100.net:5222 (ESTABLISHED)
SkyDrive  386     jakerogers   12u  IPv4 0xffffff801032dc00      0t0    TCP 192.168.3.3:57037->bn1wns1011506.wns.windows.com:443 (ESTABLISHED)
SkyDrive  386     jakerogers   18u  IPv4 0xffffff8011468c00      0t0    TCP 192.168.3.3:57265->157.56.108.174:443 (ESTABLISHED)
Router    402     jakerogers   20u  IPv4 0xffffff800fe9b320      0t0    TCP localhost.localdomain:49216->localhost.localdomain:30010 (ESTABLISHED)
USB\x20Pr 404     jakerogers    5u  IPv4 0xffffff800cdf9318      0t0    UDP *:57019
USB\x20Pr 404     jakerogers    7u  IPv4 0xffffff80102796c0      0t0    TCP localhost.localdomain:49219->localhost.localdomain:52693 (ESTABLISHED)
USB\x20Pr 404     jakerogers   10u  IPv4 0xffffff800cdfac10      0t0    UDP *:49501
USB\x20Pr 404     jakerogers   15u  IPv4 0xffffff800cdfaf00      0t0    UDP *:49502
USB\x20Pr 404     jakerogers   16u  IPv4 0xffffff800cdfa920      0t0    UDP *:49500
PlexHelpe 628     jakerogers    1u  IPv4 0xffffff801912a4e0      0t0    UDP *:*
PlexHelpe 628     jakerogers    2u  IPv4 0xffffff800cdfb658      0t0    UDP *:*
Python    667           root   14u  IPv4 0xffffff800e2ba6c0      0t0    TCP *:80 (LISTEN)
Python    667           root   17u  IPv4 0xffffff800babfc00      0t0    TCP 192.168.3.3:80->192.168.3.10:49580 (CLOSE_WAIT)
Plex\x20M 993     jakerogers   27u  IPv4 0xffffff800c795320      0t0    TCP *:32400 (LISTEN)
Plex\x20M 993     jakerogers   50u  IPv4 0xffffff801912bc60      0t0    UDP *:32414
Plex\x20M 993     jakerogers   51u  IPv4 0xffffff800cdfb4e0      0t0    UDP *:32410
Plex\x20M 993     jakerogers   57u  IPv4 0xffffff801912a1f0      0t0    UDP *:32413
Plex\x20M 993     jakerogers   58u  IPv4 0xffffff800cdf8bc0      0t0    UDP localhost.localdomain:63991
Plex\x20M 993     jakerogers   59u  IPv4 0xffffff800cdfa050      0t0    UDP 192.168.3.3:54500
Plex\x20M 993     jakerogers   60u  IPv4 0xffffff800cdf9028      0t0    UDP localhost.localdomain:61476
Plex\x20M 993     jakerogers   61u  IPv4 0xffffff801912a078      0t0    UDP 192.168.3.3:58930
Python    994     jakerogers   12u  IPv4 0xffffff800e33f880      0t0    TCP *:57121 (LISTEN)
Plex\x20D 995     jakerogers   12u  IPv4 0xffffff8011487c00      0t0    TCP localhost.localdomain:57122->localhost.localdomain:57121 (CLOSE_WAIT)
Plex\x20D 995     jakerogers   14u  IPv4 0xffffff800cdfb1f0      0t0    UDP *:1900
Plex\x20D 995     jakerogers   17u  IPv4 0xffffff80114ea160      0t0    TCP *:1949 (LISTEN)
Plex\x20D 995     jakerogers   20u  IPv4 0xffffff8019128028      0t0    UDP *:15937
Plex\x20D 995     jakerogers   23u  IPv4 0xffffff80191281a0      0t0    UDP *:15126
Plex\x20D 995     jakerogers   26u  IPv4 0xffffff801912a7d0      0t0    UDP *:8251
Plex\x20D 995     jakerogers   30u  IPv4 0xffffff8019129340      0t0    UDP *:7377
Plex\x20D 995     jakerogers   34u  IPv4 0xffffff800b5bf178      0t0    UDP *:11978
Plex\x20D 995     jakerogers   41u  IPv4 0xffffff800b5c2f28      0t0    UDP 192.168.3.3:64790->router.belkin:5351
Plex\x20D 995     jakerogers   42u  IPv4 0xffffff801146c500      0t0    TCP *:32469 (LISTEN)
Plex\x20D 995     jakerogers   44u  IPv4 0xffffff801912bdd8      0t0    UDP *:52396
Plex\x20D 995     jakerogers   48u  IPv4 0xffffff801912a948      0t0    UDP *:60778
Plex\x20D 995     jakerogers   50u  IPv4 0xffffff801912bc60      0t0    UDP *:32414
Plex\x20D 995     jakerogers   51u  IPv4 0xffffff800cdfb4e0      0t0    UDP *:32410
Plex\x20D 995     jakerogers   56u  IPv4 0xffffff800b5c2c38      0t0    UDP *:55116
Thank you to whoever can help!!!
Port already in use.
Is this a leftover from PlexConnect? Do you have other Python scripts running as HTTP server or something?
could be sickbeard or sabnzb or couch potato.
See what is using port 80:
https://github.com/iBaa/PlexConnect/wiki/Port-80-already-in-use
Nothing that I'm aware of. That's the problem. Thanks for your reply. Any ideas how to narrow it down?
Haven't heard of any of those, but will look into it. This is super frustrating, argh. Thanks for the reply.
Anyone have any ideas or any way to help me figure out what is using port 80? Still getting super confused by this. :(
I fixed the problem by uninstalling & removing all Plex Media Server files, restarting my machine, and reinstalling. This finally cleared up Port 80.
The restarting was the key there I think.
