ok so guys as the title says i have a port 80 error and i cant seem to get my plex running. heres everything you should know
This is everything my macs running on port 80
As it says - port already in use.
You have to figure out which Application is running on that port (see WIKI). Do you have "Internet sharing" enabled?
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
Python 1080 root 4u IPv4 0x945a960d4f08039f 0t0 TCP amans-mbp:80 (LISTEN)
amans-mbp:PlexConnect-master amandevgun$
Thats all thats showing up under port 80 im sure that should be open tho being that its a python file no?
earlier i had a twitter app and drop box interfearing with port 80 i just closed them and that cleared them from the ports list but this last one is being difficult.
Reboot your machine
Reboot your machine
okay well i found out how to kill the process through activity manager and killed the python file with a 1080 port and any other program interfearing with the web server this is now my plexconnect script
12:53:48 PlexConnect: ***
12:53:48 PlexConnect: PlexConnect
12:53:48 PlexConnect: Press CTRL-C to shut down.
12:53:48 PlexConnect: started: 12:53:48
12:53:48 PlexConnect: Version: 0.3.1+
12:53:48 PlexConnect: Python: 2.7.5 (default, Aug 25 2013, 00:04:04)
[GCC 4.2.1 Compatible Apple LLVM 5.0 (clang-500.0.68)]
12:53:48 PlexConnect: Host OS: darwin
12:53:48 PlexConnect: IP_self: 192.168.1.14
12:53:49 WebServer: started: 12:53:49
12:53:49 WebServer: ***
12:53:49 WebServer: WebServer: Serving HTTP on 192.168.1.14 port 80.
12:53:49 WebServer: WebServer: Serving HTTPS on 192.168.1.14 port 443.
Yet my plex from atv is saying trailers unavailble.. what now? and i did restart thanks i think thats why i had multiple python processes running which was screwing with my port 80.
wild guess here but im guessing this is a certificate issue?
Please read the “read before posting” sticky and provide all the requested information that is needed to help troubleshoot your issue any further.
Please read the "read before posting" sticky and provide all the requested information that is needed to help troubleshoot your issue any further.
i read the sticky and have no idea what your asking for.. so here.
Why have you disabled the DNS server?
...because port 53 was used as well?
:-D
And even if it is just turned back to true the ip_dnsmaster is pointed to the plexconnect machine itself, so DNS will go nowhere.
Delete settings.cfg and start again.
i love you.
Thanks to all 3 of you for your help it means alot. I can finally enjoy plex again!! :D
Cheers
