Help troubleshooting - can transcode 4K to 1080, but can't do 4K to 4K?
Yes, you are totally right!
Thanks to other responses I managed to find, I realized that the lack of HW accelerated tone mapping was the culprit. Disabling HDR tone mapping completely solved the transcoding speed problems.
I’m pretty sure I knew this long ago, but just forgot. I’ll have to re-plan my server strategy
Appreciate the nudge in the right direction! This was a small detail but was really annoying me for a while.
Thanks!
Tone mapping (the HDR to SDR part of the transcode) on Windows is not hardware accelerated, if I remember correctly.
See what speed you get when disabling tone mapping temporarily.
