I just bought an Apple TV 3 and I've done my best to follow the install guide but to no avail. Can someone help me? I'm not that computer savvy but have been trying for hours to figure this out (I have consulted the forums already).
Thanks,
Joel
Model: Apple TV 3; Firmware Version: 5.3 (6105)
DNS Server: 209.18.47.61
Device/OS for PlexConnect: iMac (mid 2011); 10.8.4
Local IP Address: 192.168.0.2
Device for Plex Media Server: iMac (mid 2011); 10.8.4
Plex Media Server: 0.9.7.28.33-f80a4a2
Local IP Address for Device PMS Installed On: 192.168.0.2
Plex Connect: PlexConnect-0.1-iOS-pre5.1
I do not know how to check the content of my Settings.cfg file
Ok, so I should enter 192.168.0.2 as the Local Address.
As for where to put the PlexConnect zip, I put in my Library (/Users/jochapma/Library) and then unzipped it and ran the terminal commands. Did I do anything wrong there?
This is what I did for mine. I extracted the files to my desktop and ran it from there. The DNS on your Apple TV should be 192.168.0.2 and you should be able to connect.
I'm also having major issues getting plexconnect to work - I'm sure it's something very simple I've overlooked, but any help you guys can provide would be greatly appreciated. Here's the required info:
Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software):
ATV3 / 5.3 (6105)
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):
192.168.2.100
The device and operating system (including version number) that PlexConnect is installed on:
HP Proliant N40L / Windows Server 2012
The local IP address of the device that PlexConnect is installed on:
192.168.2.100
The device and operating system (including version number) that the Plex media server (PMS) is installed on:
HP Proliant N40L / Windows Server 2012 (as above)
The Plex media server (PMS) version number you are running (**do not put 'latest'**):
0.9.7.22-4b5280f
The local IP address of the device that the Plex media server (PMS) is installed on:
192.168.2.100
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one.
downloaded July 4th 2013 approx 20:00Z CEST
The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
I have changed the port that my IIS runs on to deconflict that
Issue is that the DNS does not seem to be passing through traffic - once ATV was restarted I get just the 2 icons as if it were not connected to the internet - prior to that, no content was available after plexconnect install on any native app (ie movies / tv shows) or netflix
I'm completely stumped as have tried everything I can think of!
ATV3 / 5.3 (6105)
192.168.2.100
192.168.2.100
0.9.7.22-4b5280f
192.168.2.100
