What is the best PLEX library and agent to use for rips of concerts and music videos? I’d rather not have them be in my regular “movie” library, so I thought I’d just create a second movie library dedicated to music videos. But the agents I have set for movies don’t do that great a job with many of these concerts. Is there a better way to handle these rips? Thanks.
So the “movie” library is probably still the best type to use? If the agent fails, just create your own artwork? I had read through this guide earlier. It never mentioned the library type, but I assumed the instructions were applying to a “music” library. To me, concert videos are more like a movie than a music file.
https://support.plex.tv/articles/205568377-adding-local-artist-and-music-videos/
In your above post you mention creating your own text description and artwork. How do you add a text description for a non matched video?
Yes, this post was made before you could add videos to a music library.
It is a movie library, with agent set to TheMovieDatabase.
That way you can treat your concert videos like a regular movie, with Bonus content as local extras etc.
If you need to provide your own metadata, first perform a Match/Fix Match procedure during which you select the ‘Personal Media’ agent for this particular ‘movie’.
Afterwards, you edit the item and fill in the details manually.
If you a have Kodi-compatible .nfo file with all the details, you can install the .nfo importer agents and then match the item to the .nfo importer instead.
