HEVC H.265 10-bit Pixelization
Server Version#: 1.3.1.916-1cb2c34d
Player Version#: PlexMediaPlayer-2.41.0.1010-286e05db-windows-x64
In all of my 480p sources that I’ve encoded into 10-bit H.265, PMP is causing a pixelization of the video. I’ve checked everything to make sure that it’s at max quality. I even set the zoom to none, and the pixelization is still present. The new Plex does not have this issue, however. ! As you can see in this screenshot, the pixelization is horrendous, and this is just on a 1080p monitor.
This screenshot is from the new Plex:
The issue is also present with 1080p sources, but not to the extreme. From PMP:
And from the new Plex:
And lastly, file info from PMP:
Since the new Plex doesn’t support audio passthrough to my surround sound receiver for my little HTPC setup, I prefer staying in PMP. If I need to provide any other info, let me know, and I’ll go get it.
I’ve posted about it a little over a year ago, never had any answer
Yes, well, if more of us keep posting about it (kind of like how everyone of the PMP users kept posting about wanting to keep PMP for HTPC use), maybe they’ll fix this issue since H.265 is becoming the new norm and that 10-bit color does a lot to preserve the original coloring from the source.
Oh I see you’re concerned about upscaling a 480p.
You’ll get some happiness from this thread.
Happy Plexing!
It’s not upscaling that’s the issue. It’s the simple fact that PMP has pixelization issues in general for 10-bit H.265 encodes. If you look at the 1080p sources, you can see it with the text. Never once did I say I was concerned about 480p upscaling because New Plex does it just fine with all source types. PMP does it just fine with H.264 480p sources. Please read what I have to say in detail and not assume. Thanks.
That is the very first sentence of your OP.
ok thank you.
Sir, your topic contains:
  • a 1510x786 jpeg
  • a 1551x665 jpeg
  • a 3283x1094 jpeg
  • a 2921x1147 jpeg
of mastered, encoded, re-encoded, re-encoded, re-encoded material about which you are passionate.
So I’m not going to bother you anymore.
The issue still persists as of the latest PMP version, here are 3 sample pictures, from 3 differents shows, in this case, this is 1080p to 1440p upscaling.
Imgur
Media info : https://pastebin.com/Nxw8rzFb
Media info : https://pastebin.com/1NXE8SKX
Imgur
Media info : https://pastebin.com/xLJtZ3rL
DXDiag Output : https://pastebin.com/mixhKzJQ
