HEVC, Sub burn = Transcode bitrate 80Mbps?
Server Version#: 1.41.4.9399
Player Version#: Samsung Tizen Plex 5.91.0
Last night I had a friend watch a movie, everything worked fine. However any other transcodes trying to start were met with “not enough space on disk”. I have 32GB of RAM for transcodes to go into and it hasnt ever been a problem before. However the movie being watched was a relatively small file.
  • Size 6.77 GB
  • Duration 1:30:32
  • Bitrate 10698 kbps
  • Width 1920
  • Height 1080
  • Aspect Ratio 1.78
  • Video Resolution 1080p
  • Container MKV
  • Video Frame Rate 24p
This movie had been transcoded by Plex to use the entire 32GB RAM disk and had started deleting its earlier parts, I uploaded well over 60GB, for a 7GB movie??
Plex was transcoding HEVC to 80000 kbps!!!
Streamed on the left, thanks to tautulli.
His TV settings in this case are set to “Original” quality, which for this specific movie as above is 10Mbps.
Today I had him rewatch the movie and the same occurred so now here are the transcoder stats and plex logs of the offending transcode. I asked him after to test without subs, and well surprising no one the movie direct plays.
It seems fairly likely that the sub burning is causing the transcoder to forget the original content bitrate? Plex is then somehow picking a number that should be way beyond its maximum for HEVC? Surely there should be a limit on the transcode bitrate, never more than the source material at the very least?
Transcode starts at 19:27:07ish in log, i cut a few days of previous events out before hand and it cuts off before the log file fills while transcoding
Plex Transcoder Statistics.2.log (775.5 KB)
Plex Media Server.1.log (1014.2 KB)
This is the only instance of this ive had, or noticed happening. But considering people are going to want to use HEVC for lower bandwidth in most cases, should this even have been possible? Tagging @chris_decker08 here because the work you’ve done on the transcoding is otherwise wonderful, but this seems like a bug to me.
This is defiantly a bug. Are you willing and able to generate a small sample that reproduces the issue? If not are you willing to send me the entire file?
https://support.plex.tv/articles/201035968-generating-sample-files-from-media/
I can send a sample or the file that’s not a problem, do you have a preferred way of doing so?
most people use google drive
If my google drive wasnt full of backups but ive uploaded it here for you Gofile - Cloud Storage Made Simple
passowrd is : plex
I was out yesterday and it looks like the link expired. can you try again?
Hi Chris, here you go, hopefully this dd sample works for you. Gofile - Cloud Storage Made Simple
grabbed it, thank you very much
which client is your friend using? selecting original quality is really only valid for direct play, for transcoding that gets translated to maximum bitrate. If the client does not specify the maximum then we select reasonable defaults based on resolution/codec, however your friends client is specifying a maximum of 80,000k. That being said the temp drive issue has been resolved in the latest beta update.
Plex for Samsung
Client Version 5.64.1
Platform Version 5
This is what he’s watching on. Im not sure how its deciding on 80000, and it only seems to happens once the subs are being burnt. Otherwise he watches without issue.
Defiantly a bug on our end, I just needed to know which client triggered it :slight_smile:
