HEVC transcoding option not available
Server Version#: 1.41.3.9314
Plex Media Server Logs_2025-01-24_16-55-13.zip (2.9 MB)
HEVC option is not showing in advanced transcoder settings.
From what Ive read, this might be due to plex not knowing what GPU I have, since it only shows auto in the transcoder device.
Im running PMS in a lxc container in proxmox on ubuntu ltsc 24.04
HEVC encoding is a hardware-only feature.
If you don’t have any hardware to transcode with, the feature will not be available.
Iknow, I have a nvidia p400, i have hardware transcoding with h264, just not h265 - which the p400 supports
Looking through the logs, there is no entry where PMS shows that it found and identified the GPU.
That said, I suggest you check the passthrough again
