HEVC/x265 Playback issues in Web Player and PS4
Server Version#: 1.32.0.6973 or 1.32.1.6999
Player Version#: 4.100.1 or 4.105.2
Plex web interface has ongoing stutter/jitter (not buffering) issues with HEVC/x265 content that is encoded at 23.976216 FPS.
Other files encoded at 23.976024 FPS do not have these issues. H264 files at either FPS do not suffer the same problem.
The stutter/jitter happens to the Web player and the PS4 app. The Android TV app does not have a problem. These are direct playing on all devices, not transcoding at all.
Any assistance would be greatly appreciated. Thank you.
Hmm… I have around 30,000 videos. The vast majority of them are HEVC 265 at 23.9 FPS. I have no such issue either in the web player or my PS4.
Could it be something with the network? My PMS is hard-wired as is my PS4. My desktop is on wireless with a pretty strong signal.
Server Version #: 1.32.1.6999
Player Version #: 4.105.2
Can you share samples?
And can you describe the stutter in more detail? (Consistent “low” framerate? Good playback but with a periodic skip?)
I’m assuming that these files were encoded using different workflows?
My guess is that the exact framerate is a mild red herring, and that some other difference is responsible. Perhaps fixed vs. variable framerates, audio track differences, muxing differences, etc.
Thank you both for the replies.
Here is a short video showing the issue I am reporting. Audio plays fine, it’s only video related.
The only thing I could narrow down what differentiates the problematic files is the FPS differences:
23.976216 FPS - Has the problem
23.976024 FPS - Plays perfect
I am most of my testing on the local machine so I don’t think it’s network related. I have tried different browsers and other PCs with the same result.
I did not encode the files, but as I have mentioned. The only difference I can tell is the FPS. The same encoder and audio formats are used.
Hmmm… I heard no break in the audio. Are you just experiencing choppiness in the video drawing? I guess it may be FPS.
I’m not sure how you do testing on a local machine streaming through Plex. As I understand it, Plex and streaming, in general, is a network protocol, ergo it’s using a network. Now one might assume it should be a local, not network connection because the server and client are on the same machine but that’s assuming the OS is smart enough to realize it doesn’t need to use network reads. I’ve been tricked by this before under Windows.
share a sample of the file you just showed. just 30 seconds or 1 minute. obviously make sure you see the issue on your end in the sample file you create before sharing.
I have tested Jellyfin and the media in question has the same playback issues. It would seem that Plex is not the issue here.
Thank you for your replies.
