HIGH MEMORY USAGE > 15Gbyte from PMS
Server Version#: PlexMediaServer-1.21.2.3943-a91458577-x86_64
PREMIUM USER
only thing PLEX-support does do is closing TOPICS !!!
solvng problems is not their business it seems
I’ve never had a solution on a problem
Now PMS is eating up my system memory! more than 13 Gbyte !!! in less than an hour
I’m not the only one, problem is known since more than 3 years !!!
on QNAP, on SYNOLOGY, on WINDOWS, on MAC
but I can’t find the reason in the other topics
solution??
I’ve added some troubleschooting files from plex
for LOG zip-files see:
Error issuing curl_easy_perform(handle): 7 AND XML: errors - #6 by distero
Sir, copy pasting the literal same text that previously got blocked, what are the odds that this will be no different? I may need to remind you that there are community guidelines to which you agreed upon creating your account.
A few recommendations creating a new topic: There is no such thing as a plex support, not a phone number to call and so on. You got a forum, with all kinds of people trying to help. Blaming them for everything won’t get you a helpful response
Also: We see you are a Plex Pass owner (you have that little arrow on your profile photo, I don’t), no need to mention that in your topic. No one promised you that you would get better support in the forums when purchasing a Plex Pass, and Caps Lock doesn’t make this any better.
I’d suggest taking a deep breath, thinking about good and bad social interactions, then creating a new topic with a more moderate language and hope for the best :wink:
Closing in favor of existing thread / posts :
Please do not create multiple threads for the same issue.
