Server Version#: 1.27.2.5929
Player Version#: 1.21.1
When moving from one film/TV programme to another (particularly right), the animation that scrolls the line of tiles is no longer smooth on 1.21.1. It’s significantly better on 1.17.0. This is regardless of resolution for the screen or graphics card. I have tried this on a Radeon 6400 in my HTPC and on my NVidia 3080Ti. I have a slow motion video as that I can post if you can suggest a host.
Definitely not fixed in 1.22 for me. On my RX6400 (in my LP HTPC) it’s now really slow navigating to different tiles on the menu. On my desktop with a 3080ti, it’s still not smooth.
I really don’t understand how this was perfectly fast in 1.17 and they’ve broken it in recent releases.
Also broken for me. I even reinstalled windows as it was on my to-do list anyway, and this did not fix it either. I´m having this issue since Version 1.2x.x. Version 1.19.1 was the last one for me with perfectly smooth scrolling.
I also noticed a very noticeable delay in loading poster artworks, this was also way faster in v. 1.19.1.
Well, I have looked a bit more in detail at this issue. First of all, the last version that is smooth on my end is PlexHTPC-1.20.2.3110-6f190192-x86_64.
I did some testing. I extracted the installer for PlexHTPC-1.20.2.3110-6f190192-x86_64, PlexHTPC-1.21.2.3158-331d3308-x86_64 and PlexHTPC-1.22.1.3169-33807d7b-x86_64 into their folders and tried running them as a portable version - which worked fine.
Result:
V.1.20.2: UI is buttery smooth
V.1.21.2: UI is stuttery on both my machines (RTX2070Super, RTX3050)
V.1.22.1: UI is stuttery on both my machines (RTX2070Super, RTX3050)
On the RTX 3050 machine, it is very noticeable, whereas on the RTX 2070 Super machine it is very minor but in comparison with V.1.20 noticeable.
Then I tried copying the Qt DLLs from the working V.1.20 to the folders of versions 1.21 and 1.22.1 - that did not have an effect - still stuttering like a mess.
Next, I tried replacing the web-client folder found in version 1.21 and 1.22.1 with the folder from the working V.1.20 and this fixed it - it is buttery smooth again - on both machines!
@ShaggyDragon Maybe you could try that as well and see if that also fixed this for you?
#Edit: Also stuttery on my AMD Gpu machine and another Nvidia machine… - Also present in the latest version 1.23.2.3194-7787f5be. On a desktop / small screen it’s not that present but on a TV even more.
Unfortunately, Version 1.24.2.3216-59dc6103 shows the same stuttering behavior…
Is this something plex is aware of? Sorry to ping you again @gbooker02 but maybe you could take a look at this or hand it over to the “web-client” Ui team? (As I described above it seems that it is not a problem with the Qt framework)
Can we help with something on trying to fix it? (Logs already attached by me some posts earlier)
Unfortunately, it is still sluggish as hell on my windows pcs. On my RX580 machine, I booted into my arch install (just openbox as xserver window manager) and tried plex-htpc there. It is buttery smooth, so I guess this is a windows related issue.
Unfortunately, I don´t have the installer on my PC right now. I also have no idea if it would be okay to share those installer files as a normal forum user…
Maybe one of the Plex employees can help? The old download link for Version 1.20 also does not work anymore.
Still present with the newest version 1.28.3, although I think it got a little better on my Nvidia setup.
I have not tried it on my AMD system yet but I guess it is still bad.
