I have created two libraries for photos and home videos. All of my photographs have carefully manged EXIF / metadata so they all import into the correct dates on the timeline. That is except two videos…
The first is 2016-01-13 14.32.09.mp4 and second 2011-04-26 14.52.00.avi
both the created and modified dates of these files (per properties in windows 10) show dates which are in 2016 and 2011 respectively but they still appear as 1st January 1970 in the two timelines.
I clicked to edit the files (pen symbol) and saw the originally available box had 1970-1-1 in them so i changed them to the the correct dates but still remained at 1970
Any ideas what is going on with these files and how i can fix their dates? I dont believe this is a problem with incorrect dates in the files
Well the OP in that thread looks like he might have the same problem, but there is no resolution.
For the plex devs here is my mediainfo for the two files in question
File 1
Complete name : \XXXXXXX\Multimedia\Pictures\Perth\2011-04-26 14.52.00.AVI
Format : AVI
Format/Info : Audio Video Interleave
File size : 20.1 MiB
Duration : 1 min 14 s
Overall bit rate : 2 245 kb/s
Writing application : PENTAX Optio A10
Video
Format : MPEG-4 Visual
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Bit rate : 2 209 kb/s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.240
Stream size : 19.7 MiB (98%)
Writing library : DivX 1000
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 50
Bit rate mode : Constant
Bit rate : 32.0 kb/s
Channel(s) : 1 channel
Sampling rate : 32.0 kHz
Stream size : 293 KiB (1%)
Alignment : Aligned on interleaves
Interleave, duration : 36 ms (1.08 video frame)
Interleave, preload duration : 108 ms
File 2
General
CompleteName : \XXXXXXXXX\Multimedia\Pictures\Calgary\2016-01-13 14.32.09.mp4
Format : MPEG-4
Format_Profile : Base Media
CodecID/String : isom (isom/iso2/avc1/mp41)
FileSize/String : 3.97 MiB
Duration/String : 48s 716ms
OverallBitRate_Mode/String : VBR
OverallBitRate/String : 684 Kbps
Encoded_Application/String : Lavf56.4.101
I have created two libraries for photos and home videos. All of my photographs have carefully manged EXIF data so they all import into the correct dates on the timeline. That is except two videos…
You can’t edit the metadata from within Plex. Get a metadata editor and examine those two files, and correct where necessary.
Read my OP, all of my files have immaculate EXIF and metadata irrespective of photo/video. The created and modified dates are as i would expect - 2016 and 2011 for the two files respectively
