Homescreen on Plexamp 4.7 no longer respects Theme setting
Using plexamp (on a android mobile device) set settingsappearancetheme to Black.
Now go to the Homescreen and you will see the following, notice the blur’ed effect on the bottom bar.
Screenshot from 2023-05-03 18-30-48
Now select Library and you will see the following …
Screenshot from 2023-05-03 18-31-12
Homescreen does not respect the theme settings but library and all the other tabs do.
This is a regression in 4.7 and does not happen with 4.6.
4.6.3 here with black theme applied and it looks the same. I don’t believe this is a regression, the tab bar has always been blurred. You likely can’t see it on the library page because there’s nothing behind it to blur :sweat_smile:
Okay, fair enough. I’ve never noticed it before and strongly dislike blur which is why I use the black theme.
Something has certainly changed. Is the previous version available to download so I can do some comparison checks ?
