Host Plex Metadata on NTFS drive
I have a specific use case where I would like to store the Library for Plex on an NTFS partition of a hard drive so that I can boot between windows and linux and share the metadata. (so when I need to use windows for games I can run plex, too and not take my server offline)
I tried following Change Metadata Location on Ubuntu 14.04 but when I did that and started Plex it acted like I had no libraries.
I have a 500GB partition (probably overkill but I have 2TB of server space on root)
└─sdd4 Plex 500G ntfs 0FEFAC262C08CBDB
I mount that to /Volumes/plexmediaserver
Then I bind that to /var/lib/plexmediaserver
sudo mount -o bind /Volumes/plexmediaserver/ /var/lib/plexmediaserver
I navigated the files, and I could access them just fine, I checked the Preferences.xml and it looked correct. But when I start it up, nothing works.
I double checked the permissions, still no luck:
drwxr-xr-x 3 plex plex 4096 Jul 23 18:21 plexmediaserver
Is there something I’m missing here?
Thanks!
where is the media stored?
windows and linux use different path separators / vs \ and you can’t easily swap between linux/windows mounts.
also, really its impossible to do anything other than guess, unless you post the server logs.
if Plex Web works, then > settings > left side scroll bottom > troubleshooting > download logs > drop zip file into reply.
otherwise manually zip logs @
Here are the logs from my most recent try, this is after I put it back so if it does not contain when is needed I can do it again and re-post those.
Plex Media Server Logs_2020-07-23_19-06-07.zip (1.2 MB)
My thinking here is that, from what I tend to read, Windows can read ext4 drives but could very well mess it up writing. The media is stored on other ext4 mounts, but that should be a read only task. I’m trying to make it as a seamless as possible when I boot into windows. But maybe there are issues I’m not considering with trying to do it this way.
Would it perhaps work better if I were to run a virtual machine or something from Windows of linux and use my linux root drive?
Can’t be done. Windows and Linux are storing folder paths and symbolic links fundamentally different.
You cannot share a Plex data folder from a Windows Plex Server with a Plex server running on Linux.
