How can I add movies to my playlists
I am really really trying to give this new version the benefit of the doubt, but man this is all so unintuitive.
Can someone please tell me how to add a movie to a playlist from my iOS app?
Server Version#:
I’m on android and have lost the ability to do that with the new version of the app too. Nor can I edit the order of the items in any of the playlists any more.
Having the same issue. Hoping they see this and fix.
Still no fix!!! This is one of the reasons I use Plex away from home and now I can’t even create a playlist? Should be easy to correct!
Same here, the ability to add to a playlist is completely gone on iOS now. I’m REALLY tired of this new app.
Same issue. Can no longer delete movies from playlist or add to them.
There is a work around. It’s a bit annoying but if you open plex on you internet explorer on your moble you can add to playlists just not using the ap. Hope that changes soon
