Add to playlist
Hi, since the update I’ve been unable to add an episode or film to a playlist nor add playlists to the homescreen, any idea how to regain this functionality? It still works on the web app so it must be an issue with the new app
Same issue for me on Android
Same. Miss this feature if in fact it has been removed. Not finding the option anywhere on the IOS app
You wait and see if the devs add it back or not. or you downgrade. Only real options
I use playlist religiously as I shuffle massive playlists of tv and movies so it watches like live TV. I almost exclusively use playlists. Not only can I not add to them from my mobile app now - which was my primary method of doing this, but even finding the playlist category under libraries and have to scroll to the off screen playlists selection is exceptionally inconvenient. Especially when it was once the top thing on my Home Screen. Like I said, this is the main thing I use on Plex.
