How Can I Determine Bitrate
Hello - I was wondering if there is a way to determine if my installation of Plex is 32-bit or 64-bit. I have an instance on Ubuntu, and it’s updating through the OS’s software updater, but I can’t see whether I’m using 32-bit or 64-bit. Any help would be appreciated!
Server Version#: 1.29.1.6260
You can find that info specific to Plex Media Server in your server logs. The 1st line usually contains that information:
Sep 25, 2022 02:00:44.435 [0x7f5927090b00] INFO - Plex Media Server v1.29.0.6244-819d3678c - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT 02:00
on my system → Ubuntu PC x86_64 means it’s a 64bit architecture setup.
You can also check the OS architecture out in the terminal, e.g. using the command uname -m
Edit: leaving mainly the question what you’re actually trying to achieve :wink:
Try looking in /var/cache/apt/archives for the plexmediaserver package. The bitness should be indicated in the package name.
  1. To determine the bitrate of the video, without using Plex, install mediainfo package. Then use on the CLI with mediainfo <filename>
[chuck@lizum ~.2004]$ mediainfo How\ to\ Train\ Your\ Dragon\ 2\ \(2014\).mkv
General
Unique ID                                : 268384545435019238454624372053891457176 (0xC9E8FBB758E119DD1A7278366EF9A098)
Complete name                            : How to Train Your Dragon 2 (2014).mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 20.3 GiB
Duration                                 : 1 h 41 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 28.5 Mb/s
Encoded date                             : UTC 2018-02-14 01:07:03
Writing application                      : mkvmerge v20.0.0 ('I Am The Sun') 64-bit
Writing library                          : libebml v1.3.5 + libmatroska v1.4.8
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings                          : CABAC / 4 Ref Frames
Format settings, CABAC                   : Yes
Format settings, Reference frames        : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Bit rate mode                            : Variable
Maximum bit rate                         : 32.2 Mb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Language                                 : English
Default                                  : No
Forced                                   : No
  1. To determine which PMS you have installed
[chuck@lizum ~.2003]$ dpkg -l | grep -i plexm
ii  plexmediaserver                            1.28.2.6106-44a5bbd28               amd64        Plex organizes all of your personal media so you can easily access and enjoy it.
amd64 is the 64 package on Ubuntu/Debian.
  1. Verified by:
[chuck@lizum ~.2006]$ head  /var/lib/plexmediaserver/Library/Application\ Support/Plex\ Media\ Server/Logs/Plex\ Media\ Server.log
Sep 10, 2022 13:07:01.987 [0x7fae19af0b00] INFO - Plex Media Server v1.28.2.6106-44a5bbd28 - Ubuntu PC x86_64 - build: linux-x86_64 debian - GMT -04:00
Sep 10, 2022 13:07:01.987 [0x7fae19af0b00] INFO - Linux version: 20.04.5 LTS (Focal Fossa), language: en-US
Sep 10, 2022 13:07:01.987 [0x7fae19af0b00] INFO - Processor: 8-core Intel(R) Core(TM) i7-8809G CPU @ 3.10GHz
Sep 10, 2022 13:07:01.987 [0x7fae19af0b00] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Sep 10, 2022 13:07:01.987 [0x7fae19af0b00] INFO - /usr/lib/plexmediaserver/Plex Media Server
Sep 10, 2022 13:07:01.988 [0x7fae1d8851c0] DEBUG - BPQ: [Idle] -> [Starting]
Sep 10, 2022 13:07:01.988 [0x7fae1d8851c0] DEBUG - FeatureManager: Using cached data for features list
Sep 10, 2022 13:07:02.009 [0x7fae1d8851c0] DEBUG - HttpServer: Listening on IPv6 as well as IPv4.
Sep 10, 2022 13:07:02.009 [0x7fae1d8851c0] DEBUG - HttpServer: Listening on port 32400.
Sep 10, 2022 13:07:02.009 [0x7fae1d8851c0] DEBUG - HttpServer: Listening on port 32401.
[chuck@lizum ~.2007]$
Awesome, thanks guys. And as per usual, especially @ChuckPa for the very clear and concise answer :slight_smile:
