How can I disable PIN - Remove PIN link is missing
Hi, I somehow enabled the pin on my main admin account, but I want to remove it. When I “edit pin” I can reset it, there is also a “forgotten” link, but no “remove link”. How can I remove the pin?
Thanks!
Choose Edit PIN, to right of your username on Users & Sharing settings page.
Confirm Current PIN.
Click on Remove PIN, instead of entering a new PIN.
Screenshot (750)
Perfect, thanks!
