Remove PIN link is missing
Server Version#: 1.28.1.6104 - 7000
Player Version#: plex web
I don’t really like the pin but when I click to edit pin there is no link to remove pin. I tried in Edge and chrome but it’s the same. Possible bug?
You have to enter your pin before you can delete it.
Look for Remove on the next screen.
Ah That’s it. Thanks
