How can I start Plexamp in full-screen mode?
Player Version#: 4.8.0
I’m trying to start Plexamp in full-screen mode automatically when I start Plexamp.
It used to be possible that when you closed Plexamp while in full-screen mode, it also would startup again in full-screen mode. It would remember the screen size on exit. This does not seem to be the case anymore.
Is there a way to do this?
Thanks.
Plexamp doesn’t have a full-screen mode, AFAIK.
You can maximize its window, which won’t cover the task bar on Windows.
On Windows, you simply edit the shortcut to Plexamp and set it to start “maximized”.
Thanks! And then how would I do that in Linux?
Sorry, no idea. I assume there is a similar way to achieve that in Linux. Whatever desktop environment you are using.
