I have folders of lectures and each folder has 24 lectures in order. If I add them directly to plex, they don’t show up in order (they aren’t TV shows or movies) and don’t come with any metadata.
In PC, if I am playing them, I can sort by folder and play them in order but on TV, streaming sticks, Xbox, the sort by folder option isn’t there. Am I out of luck?
I each file as you mentioned and they are showing up in order. The show and season name is the lecture name but inside the season it’s showing episode 1, episode2 etc. It’s not showing the name of the lecture file - episode number.
Oh, you mean editing the title of each episode in PLEX? I thought editing the name of the file in the folder in the given format would name the episode as well.
That’ll take you a while - to name 16K files, before you edit them.
There may be a way to get the episode name embedded, but the files will need to be MP4s and you’ll have to embed the data - might as well edit them, eh?
Unless someone knows something I don’t - and we may not have ‘the perfect’ solution yet. Unmark it solved and let’s let it age for a few days.
If those files are already in the mp4 format, and their file names are already containing the title, this can be quite painless with software like e.g. mp3tag:
