How do I avoid double spaced lines in the "Summary" field in the general section of a movie?
I have a library (Movie) for Music DVD’s for official and unofficial releases. When some of the releases aren’t able to be scraped using agents, I manually type a summary consisting of artist, venue, date, tracklist (chapter list), etc… At the end of each line, I hit enter once to start a new line (to go from track 1 to track 2 for example). This appears single spaced in the editing window, which is what I want, but when I hit “save changes” and look at it, all of the lines are double spaced? Should I be using some formatting syntax? Thank you for the help.
I’m wondering the exact same thing. I’ve tried everything I can think of, but the extra line space seems to be inevitable. Does anyone have a solution for this?
I’m wondering if someone is going to answer this? The format of double spacing is quite frustrating.
This is still a issue. Using PMS Version 1.13.5.5291.
Anyone know how to fix it?
This is very much still an issue in mid-2019.
Would love to get this sorted out so that my MCU list isn’t 50 blank lines long!
