Server Version#: 1.43.5.11079
Player Version#: 2026.22.0 (2211)
Since Plex have released their new 2026 software update on Apple TVOS and iOS, all my recordings made by my HDHomeRun FLEX QUATRO via Plex are now unwatchable, as even though they are recorded and stored on the local Synology DS723+ NAS, the video constantly sticks with the buffering circle.
It plays absolutely fine on VLC Player and also the previous versions of Plex before the start of the 2026 software and it still plays absolutely fine on my MacOS Plex player (1.115.0.426-4e960a1d)
Since posting these two posts, which I have not had any feedback at all from either post, there has been at least two further updates to the Apple TVOS Plex app and am still having the issue with being able to watch back recordings on Plex Players. Also the HD Home Run is also up to date as they released a firmware the other week and so is my Synology NAS drive.
I need this fixing ASAP, as I cannot watch back any of my recordings made via Plex.
I don’t think one can really contact their support other than posting here.
Meanwhile, have you tried an alternative client? ..there are a few out there that use the AppleTV and IOS’s native player and therefore play much better than Plex’s current offering.
If all you use is the TV & DVR there is a “Force Direct Play” under settings Video & Audio that may help.
The CPU in the NAS is on the low end and is struggling with Software transcoding mpeg2 to h.264, the default of the new clients. The force direct play is the only workaround if your device can support mpeg2.
You could disable the two unused network adapters and see if that lessens the log warnings.
