How do i create two separate volumes?
Sorta noob here, trying to learn as i go
i have a WD PR2100. I have added a second drive to the unit, and I have both HDs set up in JBOD configuration. When I go to the WD interface page, it just shows one large drive instead of two separate volumes.
i’d like to take the movies file off of drive a and add it to drive b, but even after creating a share folder, i can’t seem to find it in windows explorer.
not sure what step i’m missing, any help is appreciated
It’s either JBOD or RAIDed, or in the case of the PR2100, spanning.
https://www.wd.com/content/dam/wdc/website/downloadable_assets/eng/user_manual/4779-705142.pdf#G11.1301814
Be sure the drive is detected in the WD Dashboard and is infact set as JBOD.
