I have a Ubuntu server 18.04 with multiple nics. One interface uses dchp which I use to remotely administer the device. The other interface is actually 3 nics bonded together to stream video/data across. Plex is defaulting to the dhcp interface/address and I really need it to communicate via the teamed interface (bond0). I don’t have a gui interface so I need to configure it via the command line. Help!!
You can pick the preferred network interface in the advanced network settings using Plex Web:
- Open your server’s Plex Web (e.g. https://app.plex.tv/desktop)
- go to
Settings - go to
"server" > Network - make sure
Advanced Settingsare visible - select the right NIC from
Preferred network interface
