How do I get PlexAmp to see Music Library I have added on Plex?
Plex (server) shows my music library correctly, but when I launch PlexAmp - I am unable to add any libraries. Nothing is found. I have all Online Media Sources disabled. I am not looking to use any of the online sources but local source on my NAS.
I do not find any options to search anything else. I am unsure if PlexAmp is supposed to also show the other libraries I have there, eg. movies - but those aren’t visible either.
On Plex, I added the folder manually where the music is located at.
I have disabled all remote access options for Plex.
I am attempting to use PlexAmp within the LAN I am in.
EDIT
Okay, something had corrupted my whole Plex installation and manually cleaned the Plex-files/folders from my NAS and started the progress from zero. Pretty sure this will resolve the issue related to PlexAmp too.
Edit 2: Yep, everything works now.
You can change the selected library in Plexamp in Settings > Source
I cannot get there as I cannot get the PlexAmp to even launch. It requires a library. I cannot continue without a library.
If I enable eg. Music or Podcast options under Plex → Settings → Online Media Sources, PlexAmp can see these. But I don’t want those. I’m looking to add only my local library of music to PlexAmp, but have no idea how to.
I am stuck here:
As soon as I enable eg. Music on “Online Media Sources”, PlexAmp shows me a library, but it’s not mine. It’s eg. Tidal. If I get past these and head to the
If I keep Online Media Sources enabled so I can actually launch PlexAmp, I can get to the SOURCES-menu through settings, but there’s nothing I can do there.
There isn’t adding new sources or editing old ones. Left / right clicking anywhere does nothing.
I have a feeling this issue is somehow related to PlexAmp not having permissions (?) to see the music folder on the NAS. I just have no idea how to resolve the issue.
Issue resolved.
This was about Plex Server getting corrupted after dozens of updates on the previous version. Scrubbing all Plex related files and uninstalling the package + reinstalling → everything works as intended.
