How do I install a new Metadata Agent?
There are 9 sagas, which were spread over 6 years diffusion in the US (seasons) but in Japan aired continously from the 26.02.1986 until the 19.04.1989, hence a single season on AniDB.net.
“There are supposed to be nine seasons” is wrong for both tvdb/us diffusion and Japan diffusion schedule…
That being said, you can use hama with “Dragon Ball [tvdb4-76666]” as series folder name.
The tvdb4 functionality will take all aps in the series folder with absolute numbering (128 episodes) and split it magically in 9 sagas showing as seasons in Plex.
  <anime tvdbid="76666" name="Dragon Ball">
    01|001|013|Emperor Pilaf Saga
    02|014|028|Tournament Saga
    03|029|045|Red Ribbon Army Saga
    04|046|057|General Blue Saga
    05|058|067|Commander Red Saga
    06|068|083|Fortuneteller Baba Saga
    07|084|101|Tien Shinhan Saga
    08|102|122|King Piccolo Saga
    09|123|153|Piccolo Jr. Saga
  </anime>
You wanted something like that i guess ?
Yes, thank you.
Hi, i am also new, but fount the (debian) /yar/lib/plexmediaserver/LIbrary/Application Support/ Plex Media Server/Plug-Ins directory.
I put in tree new agents and granted “read/execute” all rights for different users (plex / root).
But even after PMS restart i do not see any of the agents where it should be…
What log can i look at / post here to find out what is missing?
thanks…
Have a look inside Plex Media Server\Logs\PMS Plugin Logs\com.plexapp.system.log
The agent folder ends in ‘.bundle’ and have ‘Code’ folder inside, like:
Plex Media Server\Plug-ins\Hama.bundle\Contents\Code_init_.py
chmod/chown +R !!
Is there any way to unsubscribe from this discussion? I keep getting emails about this discussion that I have no interest in any more.
me again - the plugin has started but hasn’t read any nfo file yet.
somebody to guide me (to another auth issue?)
2018-04-02 15:40:58,020 (7f0063fff700) : DEBUG (networking:166) - Requesting 'http://localhost:32400/library/metadata/25521'
2018-04-02 15:40:58,023 (7f0063fff700) : ERROR (networking:219) - Error opening URL 'http://localhost:32400/library/metadata/25521'
2018-04-02 15:40:58,024 (7f0063fff700) : CRITICAL (agentkit:1014) - Exception in the search function of agent named 'XBMC .nfo Importer', called with keyword arguments {'openSubtitlesHash': '8be988e1851889bb', 'name': 'Egon Schiele \xe2\x80\x93 Exzesse', 'plexHash': '9a73c90b2af3b0a989b63842e74bd62ac0310055', 'filename': '%2Fmnt%2Fmedia%2FFILM%2FEgon%20Schiele%20%E2%80%93%20Exzesse%20(1981)%2FEgon%20Schiele%20%E2%80%93%20Exzesse%20(1981)%20h264-576p%20AC3-2ch%2Emkv', 'year': '1981', 'duration': '5355392', 'guid': 'tt0082311', 'id': '25521'} (most recent call last): File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/agentkit.py", line 1007, in _search agent.search(*f_args, **f_kwargs) File "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins/XBMC .nfo Importer.bundle/Contents/Code/__init__.py", line 18, in search xml = XML.ElementFromURL(pageUrl) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/parsekit.py", line 344, in ElementFromURL method=method, File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/api/networkkit.py", line 67, in _http_request req = self._core.networking.http_request(url, *args, **kwargs) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 370, in http_request return HTTPRequest(self._core, url, data, h, url_cache, encoding, errors, timeout, immediate, sleep, opener, follow_redirects, method) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 141, in __init__ self.load() File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Versions/2/Python/Framework/components/networking.py", line 181, in load f = self._opener.open(req, timeout=self._timeout) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 444, in open response = meth(req, response) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 557, in http_response 'http', request, response, code, msg, hdrs) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 482, in error return self._call_chain(*args) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 416, in _call_chain result = func(*args) File "/usr/lib/plexmediaserver/Resources/Plug-ins-6de959918/Framework.bundle/Contents/Resources/Platforms/Shared/Libraries/urllib2_new.py", line 565, in http_error_default raise HTTPError(req.get_full_url(), code, msg, hdrs, fp) HTTPError: HTTP Error 401: Unauthorized ``
What are you trying to do, use the AHK hotkey.
