To move the PMS Library directory on QNAP, you have some keyboard (typing) to do.
I will write out the instructions presuming /share/CACHEDEV2_DATA/Plex is where we will move PMS to. Please edit appropriately
Create the shared folder you want on the SSD. I recommend something without spaces. e.g. “Plex”
Stop PMS
open a SSH session.
cd /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer
tar cf - ./Library | (cd /share/CACHDEV2_DATA/Plex ; tar xf - )
mv Library Library.save
ln -s /share/CACHEDEV2_DATA/Plex/Library .
The steps above do the following
get in the Plex directory
Create a copy of Library on /share/CACHEDEV2_DATA/Plex/Library
Rename the Library directory in this directory (get it out of the way and keep as a temporary backup )
Link the new location to here where Plex expects it
When this is complete without errors, Start PMS
When you are happy with the results, you can delete Library.save with rm -rf /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library.save
Be advised, if you uninstall PMS, this will be deleted and you will need to be redone.
Hi ChuckPA,
Thanks for your support. Much appreciated.
Before I try this method can I make sure that this only moves the data folder. I want to keeps all my movies, tv shows on my normal HDD drive. The Library directory suggests that this is my entire media Library?
Thanks,
Leon
As you can see by the commands I’ve listed, only the Library in ~/.qpkg/PlexMediaServer is relocated. Nothing else is moved.
PMS’s executables remain in their default installation location. Your media is not touched. It would take a lot more commands to move that around
Hi Chuck,
Thanks for the help.
My PMS is stored on CACHEDEV1_DATA. However, I don’t know how to create a share on my SSD drive. Do you know how to do this, so i can actually follow your steps? I’ve attached a screenshot of my QNAP storage below:
Now you have both the CACHEDEV path and the share (destination directory) to put your Library in.
There is an added bonus to doing this. From this point forward, you’ll be able to get your PMS logs directly by opening that share and drilling down to the Logs directly in File Station
Thanks.
Almost there. I get this when I go to create a share. I just have one disk volume, and don’t know how to create another disk volume for my SSD:
Available disks 0/6. I’ve create a RAID5 on my 4 HDD drives. And switched on Cache acceleration on my SSD drives.
It won’t allow me to select the SSD device.
If you have both SSD as cache volumes, you can’t create data volumes on them concurrently. QTS doesn’t support us partitioning devices this way. It also doesn’t let us cache on the system volume (for the same partitioning reasons)
Edit: IIRC, you can cache multiple volumes on a single SSD if you create it that way
Yes, turn off caching of your main volume (for now).
Add that SSD as a new volume and place the share on it.
Later, when you have the extra time/funds, drop a 250/500 GB SSD in another slot
When I create a new share on the new volume, I’m assuming I should name this something like ‘Plex2’ for now, and then rename it to ‘Plex’ after I’ve copied from original location? It turns red as I write ‘Plex’.
Make the first PMS share manually, point it to wherever PMS is currently installed (enter path manually) and make a ZIP backup of the Library you find there.
I did the following (with PMS stopped).
Made a backup (ZIP) of the existing Library through FileStation (For me, the path is /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library)
Made a directory on the new volume
Edit the Plex share definition and make it point to the new location on your SSD
Unzipped the Library there (my new path is /share/CACHDEV4_DATA/PlexMediaServer/Library
Verified I didn’t get /share/CACHEDEV4_DATA/PlexMediaServer/Library/Library … This would cause it to fail .
Deleted the original library (rm -rf /share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library)
Created a symbolic link (ln -s /share/CACHEDEV4_DATA/PlexMediaServer/Library /share/CACHEDEV1_DATA/PlexMediaServer/Library)
Ok, I’ve stopped PMS.
However, how do I make a backup (ZIP) within FileStation? Can’t see that file path. I can see the Plex folder.
Forgive me if I’m being slow. I’m not used to this.
