How do I remove Plex from Win Laptop where the wifi is not connecting?
Hello
I have Plex set up on my old Windows Laptop. The Wifi is no longer working on this PC. As a result I cannot use Plex as there is where my server is set up. How do I either set up a new server on Plex on my new laptop, or, continue to use my old server on my new laptop? Keep in mind, I have no way to connect the old laptop to Wifi.
thanks
alex
Can you connect a usb drive to the old laptop and copy some large files?
This is how you move to another computer. It is generally straight forward if you are moving to the same operating system. https://support.plex.tv/articles/201370363-move-an-install-to-another-system/
if you want to delete from computer completely
https://support.plex.tv/articles/201941078-uninstall-plex-media-server/
If do not move it and decide to start from scratch on new computer then you should remove it from authorized devices as well so your account knows it is gone.
https://app.plex.tv/desktop/#!/settings/devices/pms
Why not use LAN or a USB Wlan Adapter?
Acronis Backup can Backup your full Windows and completely restore on another PC.
