How do I search for tv shows
So I can only find certain networks and i am unable to find a list of the channels that it says i should have for my area.
If someone could help me with this i would be appreciative. I do have the Plex Pass
TV tuner setup already I presume?
What kind?
Is the TV tuner working outside of the Plex environment?
TV tuner setup in Plex?
Not enough info…
Sorry new to this i do not have a tuner hooked up to my server, and i still have channels like NBC and Spike, etc. when i did the set up it asked for my zip and then it showed a ton of channels that i should get. Thank for the response hopefully this will help with my question a little more.
What were you setting up when it asked for you zip?
No Tuner means no DVR/LiveTV.
I believe you are asking about Plex Channels maybe?.. Are these channels that appear in a section of Plex called “Channels”?
If so, then the DVR/LiveTV is not where you would get these.
DVR/LiveTV comes from a TV Tuner and is only accessible by said tuner.
So you are referring to channel as in apps that can be installed in Plex
not local TV Stations being broadcast that can be received when you have a tuner configured in your Plex setup.
If you are wanting to be able to watch/record your local TV stations you will need to purchase a compatible tuner device and configure it in Plex DVR.
Is there a place to get additional channels or is this itt until i get a tuner. Thanks again for the help
The only place for channels is under the install channels. Many of the channels that I installed at one point seemed almost useless to be honest. Launch a channel and try to stream content and it would say something to the effect of no content available. I finally gave up on most channels except a few which to be honest I rarely use.
