How do I uninstall Live TV?
I’ve moved and I cannot do Plex Live TV at my new location. I have been looking and looking and I do note see how to remove the HD Home Run device and completely uninstall Live TV. How is this done?
Can’t you just delete the DVR?
@clinkadink Thanks for the reply :slight_smile: That partially worked. The HD HomeRun is gone but I still have the “Program Guide” on home spinning forever, I guess still trying to load programs guide. How can I make that go away?
@clinkadink Oops, actually that did not work. A red alert popped up said “There was a problem removing your DVR”. Can’t remove it that way :frowning:
Have you tried restarting the PMS and retrying?
I rebooted Plex and everything seems Ok now. Thanks @clinkadink
