Unable to Delete DVR
Server Version#: 1.14.1.5488Plex Media Server Logs_2018-12-22_07-38-18.zip (695.2 KB)
I have a new issue on OSX Mojave that prevents me from using my HDHomeRun TV. The guide constantly runs and it will not allow me to remove my DVR to re-add it.
You should be able to power of the HD HomeRun unit. Then while it is off, log into the PLEX Media server and go to Live + DVR, then remove the DVR. That should work.
Tried that and it was unsuccessful. Is there a manual way to remove it from the config files?
That I’m unsure of, but I think there should be a file for the configuration setting. I’ll have to look.
same problem. Use HRTunerProxy and Guide update is running since week. Deletion of the DVR isn’t possible.
Same here, I removed my HDHomeRun from the network, I delete it from Plex and it comes back. Then the guide just sits there spinning. Anyone have an answer to this?
Same issue.
I’m having the same issue, its driving me insane
I’m having the same issue.
I’m having same issue can’t load them can’t remove it since last update.
i fixed it on mine before you hit delete DVR power off the tuner and it will delete no problems, i was able to re add it again after that
Yep, this worked for me too. I unplugged the HDHomeRun, restarted PMS, and deleted the DVR successfully. Wow was figuring that out painful.
Having same issue. Work around not working.
