I want to change the order channels appear under live tv, i saw a reference to a manage channels function after pressing … but only options i have are manage favorites or manage guide sources, was manage channels removed ?
strong textServer Version#:
Tuner Make/Model: bgt blackgold freeview tuner
Guide/Lineup name:
Using XMLTV?: no
Channel number/Name: all
You can absolutely make your channels any order you wish. If you use a backend such as TVheadend / xTeVe (possibly others) and your own XMLTV guide the channels can be any order you want.
