I have recorded several programs with plex dvr, but I can not get any of them to play. How do you playback a plex dvr recording?
I normally hover on the recording from the Recently Added section and click the play button.
Thanks Johnm but where are my recordings? I can not find the dvr recordings that I just made.
Should be in the library you specified when you setup the recording. Should also show on the home screen after you login to your Plex Server.
I chose the TV Shows library, but they are not there.
Are they still in the grab folder in the library?
What is the grab folder?
I do not see anything that says grab folder
Grab folder is in the root of whatever folder you are recording to.
I still don’t understand. I guess it just does not work for me, as usual.
I don’t use Plex DVR anymore. Thanks for all your help.
