OK>>> set up the DVR with my Home Run Connect… It seems to be working fine, but I am having trouble figuring out where the recordings land on my Hard drive… HELP!!!
Should be in whatever folder location you specified for the Library you told the recording to use.
thanks for the very quick response. but I am still a bit confused about the structures that Plex uses…
Not sure what you are meaning with that last post.
You setup a library and configured it with a folder location for files:
You then configured a recording specifying the Library to use for the recording:
When the rrecording is complete it will be in the folder location you specified for the library.
thank you again… this is starting to make sense now
