I wasn’t suggesting that you enable this. In fact, I’ll go as far as to suggest you don’t. My experience is that it doesn’t work well and can cause some issues (tuners not being freed in a timely manner). However, it is located in your DVR settings (Settings → [Server Name] → Live TV & DVR, gear icon → Convert Video While Recording).
As for your logs, everything looks fairly straight-forward there. Plex Media Server.log shows the recording you mentioned above. It runs through the transcoder, but it is only copying the codecs unmodified, so there’s not much processing overhead there (as I’d expect).
Nov 22, 2023 16:30:00.698 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Grabber: Going to record for 1800 seconds, final URL is http://192.168.50.23:5004/auto/v2.1
Nov 22, 2023 16:30:00.698 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MediaRecorderVirtual: setting stop time to 2023-11-22 17:00:00
Nov 22, 2023 16:30:00.698 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] DVR:Segmenter: Creating a new recorder for http://192.168.50.23:5004/auto/v2.1.
Nov 22, 2023 16:30:00.701 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Grabber: Waiting for a tuner on device://tv.plex.grabbers.hdhomerun/1094E911 (2 available) for at most 1800 seconds.
Nov 22, 2023 16:30:00.701 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Grabber: Allocated a tuner on device://tv.plex.grabbers.hdhomerun/1094E911 (1 left)
Nov 22, 2023 16:30:00.703 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] We're going to try to auto-select an audio stream for account 1.
Nov 22, 2023 16:30:00.703 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Selecting best audio stream for part ID -1 (language: )
Nov 22, 2023 16:30:00.703 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Audio Stream: -1, Subtitle Stream: -1
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MDE: Selected protocol hls; container: mpegts
Nov 22, 2023 16:30:00.704 [9176] ERROR - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Unable to find title for item of type 5
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MDE: analyzing media item -1
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MDE: : no direct play video profile exists for http/mpegts/
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MDE: : no direct play video profile exists for http/mpegts//
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MDE: : codec is unavailable for analysis
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] MDE: : selected media 0 / -1
Nov 22, 2023 16:30:00.704 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Cleaning directory for session 116d201a-94b0-4512-a7a4-03544fd49bdf ()
Nov 22, 2023 16:30:00.705 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Starting a transcode session 116d201a-94b0-4512-a7a4-03544fd49bdf at offset -1.0 (state=3)
Nov 22, 2023 16:30:00.705 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] Streaming Resource: Added session 0000027E5BF064F0:116d201a-94b0-4512-a7a4-03544fd49bdf
Nov 22, 2023 16:30:00.705 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] TPU: hardware transcoding: enabled, but no hardware decode accelerator found
Nov 22, 2023 16:30:00.705 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4] TPU: hardware transcoding: final decoder: , final encoder:
Nov 22, 2023 16:30:00.708 [9176] DEBUG - [Req#24c24/Grabber/b117a4d4bcf5cd6721366d0039c96fe46e8c65e4/JobRunner] Job running: set "FFMPEG_EXTERNAL_LIBS=\\\\?\\C\:\\Users\\kevin\\AppData\\Local\\Plex\ Media\ Server\\Codecs\\a31c019-4614-windows-x86_64\\" & set "X_PLEX_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" & "C:\Program Files\Plex\Plex Media Server\Plex Transcoder.exe" -noaccurate_seek -ignore_unknown -scan_all_pmts -1 -rw_timeout 30000000 -reconnect 1 -reconnect_streamed 1 -reconnect_delay_max 30 -fflags +discardcorruptts+fillwallclockdts -probesize 20000000 -i http://192.168.50.23:5004/auto/v2.1 -map 0:V? -codec:V copy -map 0:a? -codec:a copy -map 0:s? -codec:s copy -break_non_keyframes 1 -segment_format mpegts -f ssegment -individual_header_trailer 0 -segment_time 1 -segment_start_number 0 -segment_time_delta 0.25 -segment_list http://127.0.0.1:32400/video/:/transcode/session/116d201a-94b0-4512-a7a4-03544fd49bdf/155920a5-feb5-4983-81eb-bbd71df2e533/manifest?X-Plex-Http-Pipeline=infinite -segment_list_type csv -segment_list_size 5 -segment_list_separate_stream_times 1 -segment_list_unfinished 1 -max_delay 5000000 -map_metadata -1 -map_chapters -1 media-%05d.ts -y -nostats -loglevel quiet -loglevel_plex error -xioerror -progressurl http://127.0.0.1:32400/video/:/transcode/session/116d201a-94b0-4512-a7a4-03544fd49bdf/155920a5-feb5-4983-81eb-bbd71df2e533/progress
I’m not really sure what was going on on the client system at that time, but it likely didn’t have anything to do with the in-progress recording.
There is a certain amount of overhead involved in just running the client and monitoring what’s going on on the server, but nothing I’d consider intensive.
Perhaps it’d be worth testing shutting down laptop 2 and just scheduling a recording on laptop 1 to make sure everything is working as intended.
Yep, yep, and yep. All spot-on.
