Hi You specs look fine, it should be able to steam without issue. The most likely issue with be your bandwidth. What is your DL and you UL.
You need a minimum download speed of 3 Megabits per second to watch a single video stream in clear, standard definition. The best Internet speed for HD streaming is 5Mbps, and if you go all the way up to 4K streaming, or ultra HD, your bandwidth should start at 25Mbps.
@umaradam I will think about it, the Apple TV came with a DirecTV Now subscription and I had the Roku for a while acquiring a 3rd device will be insane
@aaseef021_gmail.com it is a local network I should not have issues with connection, both the Roku and the Apple TV and even the Samsung TV are wired, the PC where the Plex Server is wired as well, the speed should be 1Gbps.
Interesting, than it should not take that long. Maybe you can run a wireshark trace when viewing this to see what is occurring when steaming this. Maybe there is something else being ran in the background.
@umaradam do you know if the Xbox One X Plex Client does required transcoding also when subtitles are enabled? Where I can find that kind of information?
Plex on xbox/ps4 is buggy from my experiences in the past. Best thing to do is ask around on the forums. I use a shield as my server and client so i know for sure it works on there.
So @umaradam ⦠I guess that when you said āuse an nvidia Shieldā you were referring to setup a Plex Server in there like shown here right? I have tried a similar movie and still transcoding (see below)
@Peter_W Wow thank you so much ⦠it does play it without any issues indeed. See below:
I will try a few more and if I donāt run into any issues I will pay for the full subscription which apparently is mandatory for use the tool unless I miss something
Sadly is not working for me, I just got a brand new one and you saw the result. Is not working I will do more testing and I will return it if it does not work.
