How I think the new interface could be improved
If I’m stuck with out the left menu system (which was great and efficient)
Give an OPTION to have when Plex turn on it go straight to the top menu - not the last played item - you can leave that on the home page but don’t make the user have to go up to get to the menu - which is more likely - I want to watch the last movie I played again or look for something new?
Give an option to always show the selected library in the same fashion - if I select the standard list for TV shows great but if I want to show movies by collection - give an option to always show them that way so I don’t have to go to that option after selecting movies every single time.
Give an option to always show the number of media in any library or collection.
Frankly since you seem desperate to “clean up” the interface, make the TV and last played as options in the media menu and then you don’t really need the home or plex tv as separate options - for me this would be more efficient.
Could be improved by trashing it and returning to the version that worked!
@boe_d “Give an OPTION” is the correct answer.
There used to be a way to un-pin items not used. No more. When will software developers get it that people want to be able to tweak and customize to THEIR needs and likes?!
