How to add EPG data from another location?
Server Version#:
Tuner Make/Model:
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
I have a couple of channels not found in my local EPG data and I’m trying to figure out how to add it. On Plex’s help page is says there is a button called “+ Add channels form another lineup/location” (Live TV & DVR (Set Up and Manage) | Plex Support), but on my setup page I don’t see it under the EPG location.
Is there somewhere else I need to look for this?
You can only do that when you are first adding the device. Delete DVR, wait a minute and then re-add.
Thanks! I found it now.
