Live TV OTA Add channels from another lineup / location and allowing unknown channels
Server Version#: Version 1.28.2.6151
Player Version#: 1.52.1.3195-a0c4d5e9
Tuner Make/Model: HDHR4-2US
Guide/Lineup name: Local Broadcast Listings
Using XMLTV?:
Channel number/Name:
This seems silly. Living in an area where I’m between multiple cities, and with the seasons channels come and go, OTA channels often change for us. I’m not sure why i should have to delete my tuner and re-add it every time just to get the option to choose another region / location. Can’t that be added when choosing manage on the edit screen below EPG location (below)?
In addition to this, please create a generic channel EGP with 1 hour blocks of “unknown” as a dummy default EPG that can be assigned to multiple channels for ones that do not yet have a real EPG for them. I get the need for an EPG for a channel on the design between live tv and DVR but why should i forced to not be able to watch it? There’s workarounds of using dummyXML channels but plex has yet to do this natively.
Delete the DVR and when you re-add it add a second zip code so the stations are available on a rescan.
I get that, but shouldn’t have to do that. I should have the option even after the fact to try and get a channel to come in the guide.
